Samsung head change tools - HddSurgery
http://forum.hddguru.com/viewtopic.php?f=22&t=17749
Author:  helpdisc [ November 23rd, 2010, 4:22 ]
Post subject:  Samsung head change tools - HddSurgery
this is our first manual,
more will folow
Nikola
File comment: samsung head change tools - HddSurgery
Samsung Head change tools.pdf [1.45 MiB]
Downloaded 4090 times
Author:  helpdisc [ November 25th, 2010, 7:45 ]
Post subject:  Re: Samsung head change tools - HddSurgery
Seagate head change tool 7200.10 HddSurgery manual
Nikola
File comment: Seagate 7200.10 manual
HddSurgery Seagate 7200.10 head change tool.pdf [1.55 MiB]
Downloaded 3295 times
Author:  zebong [ November 29th, 2010, 9:40 ]
Thanks a Lot Nikola :)
Great work.
Author:  helpdisc [ November 30th, 2010, 11:09 ]
We are not seling our manuals or videos. You can see them on our web site or here.
Author:  helpdisc [ December 6th, 2010, 11:49 ]
Seagate head change tool 7200.11 HddSurgery manual
Nikola
File comment: Seagate 7200.11 manual
HddSurgery Seagate 7200.11 head change tool.pdf [1.31 MiB]
Downloaded 3347 times
Author:  bss [ January 29th, 2011, 21:08 ]
Thanks Good job
What is your web address?
Author:  bss [ January 29th, 2011, 21:16 ]
I think this is it:
www.hddsurgery.com
Do you have a package which includes all products?
Author:  helpdisc [ January 30th, 2011, 4:25 ]
we do not have it but we can make some np
Author:  poehere [ September 13th, 2011, 2:53 ]
Nice tools and a nice manual to go with them. Good job keep it up Nikola
Author:  Keatah [ April 26th, 2012, 9:53 ]
Will you be adding platter extraction and swap tools to the lineup anytime soon?
Author:  helpdisc [ April 27th, 2012, 3:46 ]
You mean Samsung platter extraction?
We do not see them stucked at all, what drives You get?
Author:  selftest [ May 5th, 2012, 22:32 ]
Nikola
Thanks :D
Author:  Keatah [ May 5th, 2012, 23:39 ]
The two-platter version of the HM160HC. I don't remember the exact model number offhand, but it may be HM160HJ or something very similar.
The motor was seemingly damaged by physical impact at construction site. The drive housing is bent ever so slightly near the spindle bearing. If you put the drive on a flat surface, one end corner is ~2mm higher than the other. It doesn't sit completely flat like a non-damaged drive would.
So it would seem that platter extraction is the only way to go here. As far as I can tell the surfaces are not damaged. The head assembly may also be undamaged. I don't know at this point.
According to the customer there's a mix of personal and work data, with the personal data being more important of course.
I can also improvise and come up with something.
