Joined: December 25th, 2018, 3:15 Posts: 11 Location: Varanasi
Technology mode key : ..........................: OK
RAM: Read HDD Info : ................................: OK Heads number : .................................: 2 Head map : .....................................: 3 SA Cyl Count : .................................: 256 Serials Mark : .................................: 0xFE16 Control version : ..............................: 63B0
Zone allocation table : ........................: Err
ROM: Read Rom Infos : ...............................: OK ROM Data Size : ................................: 192 Kb ROM version : ..................................: 03.36B ROM generation : ...............................: 03.36B Link table version : ...........................: 03.0Q ROM Firmware version : .........................: 00030036
ROM Modules: Flash ROM dir reading : ........................: OK Switched off heads : ...........................: Yes Heads number : .................................: 0x2 Heads number in use : ..........................: 0x2 heads map : ....................................: 0,1
SA Module Dir Loading... Load SA Module dir : ...........................: Error, suggest to load from the file Configuration reading : ........................: Err
| Attachments: |
