Post new topic Reply to topic  [ 267 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14
 Post subject: Re: HDDSuperClone - A new Linux hard drive cloning/imaging t
PostPosted: July 17th, 2026, 3:46
Adding some interesting new features to OpenSuperClone. The program will soon support serial commands both through the UI and script engine
with any UART adapter. I've added some scripts for Seagate F3 drives (some obviously quite dangerous).
Also in the process of building some companion hardware that combines relays, current monitoriong (and overcurrent protection), and an integrated
serial port. Hardware is proprietary but the software implementation is obviously open source so people will be able to build their own (if they want to
waste as much time on this as I have).
Sometimes I build stuff - https://github.com/ISpillMyDrink
PostPosted: July 17th, 2026, 5:40
But this is something you'll be offering?
PostPosted: July 17th, 2026, 6:12
Yes, I'm working on a little kit consisting of the main power cycling board, an expansion card for M.2 drives (working on native NVMe support in OSC aswell),
and H10/H20 adapter for Optane drives.
PostPosted: July 17th, 2026, 6:30
USB or SATA - SATA current monitoring with decent software alone is something I know would be very useful as an addition to the versions of pc3000 without it. Would be even nicer if it was also usb.
PostPosted: July 17th, 2026, 12:38
If I understand correctly, Deepspar's USB Stabilizer can implement a "soft" reset by interrupting the USB data lines in USB storage devices. Perhaps you might consider adding a differential switch or a USB redriver?
HD3SS3412, Texas Instruments, 4-Channel High-Performance Differential Switch, 3.3V, WQFN-42:
http://www.ti.com/lit/ds/symlink/hd3ss3412.pdf
USB redrivers:
https://www.ti.com/product-category/interface/usb-ics/usb-redrivers-multiplexers/products.html
On the SATA side ...
MAX4952, Maxim, Quad Equalized 1.5/3.0/6.0GT/s SAS/SATA Redriver, 3.3V, TQFN-42:
https://datasheets.maximintegrated.com/ ... AX4952.pdf
PostPosted: July 21st, 2026, 15:24
It's certainly something to think about; I must admit I hadn't thought about just disrupting the data lines
and I don't even know how most USB devices react to that / whether that would actually make much of
a difference for most SATA attached storage.
I'd love some more info on that.
PostPosted: July 24th, 2026, 13:13
"Using a differential switch to control $D+/D-$, followed by a $V_{BUS}$ power switch controlled via a script inside OpenSuperClone, will give you a result very close to how professional DeepSpar devices operate in a Linux environment."
cron
