 Post subject: WANTED PCB for WD6400aaks
PostPosted: March 25th, 2010, 8:52
MODEL: WD6400AAKS-75A7B0
S/N: WMASY250208
DCM: HARNHV2CA
ORIGIN: MALAYSIA
LBA: 1250263728
FIRMWARE: B0
PCB:2061-701537-E00 07PD3 XW 5B22 YGQC 3 0001040 9041 (WHITE LABEL),
2060-701537-003 REV A (ETCHED)
 Post subject: Re: WANTED PCB for WD6400aaks
PostPosted: March 25th, 2010, 20:28
hi,
have in stock. please contact me by email or MSN. could be help you program firmware into MCU. thanks.
data recovery service[/b]
PostPosted: March 26th, 2010, 2:34
We have this working PCB too, pls contact my hotmail.
Eric
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: March 29th, 2010, 4:45
Before you go buy the donor drive, what's wrong with your hard drive??? This AAKS model is often time out side of DIY arena due to the PCB design.
PostPosted: March 29th, 2010, 6:19
Agreed, for this model, you also need to reprogram rom. ^^
PostPosted: March 29th, 2010, 9:52
Well, problem is that it won't power up, tried 2 different sources. I used it via USB adaptor (have an older pc w/o SATA) to transfer files from another drive for reformat. After reformatting the other drive, this one failed. All I have on this drive are PSP & PS2 backup iso files. Everything else on it is either expendable or on another pc.
I did however plan to replace my existing secondary drive (seagate 120gb) with this one(via pci SATA controller). The problem drive was only used for 15 months in my brother-in-law's pc....they thought it crashed and bought a new 750gb from Dell.
PostPosted: March 30th, 2010, 0:37
Awwww.
I would say RMA the drive. It will cost you more to find the replacement PCB that will work on your drive.
