Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: Samsung Spintpoint SP2514N power overload
PostPosted: March 4th, 2009, 22:08
Hey everyone. I was given a Samsung SP2514N from an external Lacie enclosure. The person admitted to plugging in the wrong AC Adapter which caused the drive to break. It doesn't spin up or respond in any way. I posted a thread in the buy/sell section for a PCB. How are Samsungs when it comes to PCB replacement. Will any ol' SP2514N work or should I try to match part number / PCB numbers as well.
The information would be nice to have, but by no means is critical.
P.S. Does anyone know any good pro services in Sacramento, California? It would be nice to have a company to refer.
 Post subject: Re: Samsung Spintpoint SP2514N power overload
PostPosted: March 5th, 2009, 1:39
There is a certain chance the damage is limited to pcb - I repair the pcbs too. If drive click/no Id/id but doesn't read with new pcb it's time for a pro. Simple.
PostPosted: March 10th, 2009, 13:20
Samsungs are relatively sensitive to FW mismatch, so it is not easy to find a compatible pcb.
PostPosted: March 10th, 2009, 16:27
pepe, are you REALLY sure ? :mrgreen:
PostPosted: March 11th, 2009, 3:48
Exactly what I wanted to say.....
are you really sure pepe?
I just hate spammers...It was a Spammer, who ruined my life!
PostPosted: March 11th, 2009, 6:01
Samsung knowledge for sale, code included, everything you should have known, ACE and probably even Samsung didn't say you and you never asked... before I repent... before I retire... before I reach 2000 posts here ...place a bid. :D
PostPosted: March 11th, 2009, 6:39
I'll bid you a Del Piero signed Italy home shirt. :lol:
PostPosted: March 16th, 2009, 20:41
I mean it is not that dificult for me, but it might be dificult for one without a stock of samsungs and FW.
PostPosted: March 17th, 2009, 3:13
About the Fw, if you rely only on ACE... Good luck.
PostPosted: March 28th, 2010, 6:11
Same issue here ... This one was also originally in a Lacie enclosure.
Samsung SP2514N (250GB/7200rpm/8M/PATA) RevA (LBA 488,397,168 250.0GB P120)
The electronics seem to be shortcircuited now and I really need to recover the data. Any chance that someone might be able to sell me a circuit board for this thing?
I have no clue where to look for the FW version, but the closest thing to a version number I see on the label is 2006.11
Thanks in advance,
Jurgen
PostPosted: March 28th, 2010, 19:02
The electronics seem to be shortcircuited ...
Does your board look like this one?
http://www.ixbt.com/storage/ata2005/sam ... -plata.jpg
If so, set your multimeter to the 200 ohms range and measure the resistance of the two TVS diodes near the power connector. The 12V diode appears to be the vertically mounted part near the screw, and the 5V diode appears to be the horizontally mounted part a little to the right of the connector.
This article should help you identify the components:
Confirm that neither of the zero ohm links are open. They should both test as shorts. If either is open, replace it with a 2A picofuse, or bridge it with a wire.
You can remove the shorted TVS diode by snipping it out with side cutters. The drive will work OK without it, albeit without protection on the affected supply rail.
Good luck.
PostPosted: March 30th, 2010, 5:02
Great! the 5V TVS measures 6Kohm so I'll short that one and see what it does ... BRB! (the 12V is shorted, so Ok)
PostPosted: March 30th, 2010, 5:04
NONONONO
Just the opposite.
They must be open circuit to be good!
Dobre
Murphy was an optimist
PostPosted: March 30th, 2010, 5:16
Negative.
I can smell the fried PCB from here. :(
PostPosted: March 30th, 2010, 5:28
just in time:-) I removed both diodes but no sign of life
PostPosted: March 30th, 2010, 5:46
ok ... I removed both diodes but it doesn't seem to boot up. Anything else I can measure to pinpoint the problem?
PostPosted: March 30th, 2010, 6:40
pics can be found here: https://www.yousendit.com/download/bFFO ... aVB2Wmc9PQ
PostPosted: March 31st, 2010, 5:26
You needed to only remove the diode that measured zero ohms.
Now you need to find the zero ohm link that doesn't measure zero ohms. That will be the bad one. Replace it with a piece of wire, or a 2A picofuse.
I have identified them for you here:
http://www.users.on.net/~fzabkar/temp/Z ... _Links.jpg
PostPosted: July 31st, 2011, 9:57
I also have a samsung SP2514 hdd.
I followed the advices of fzabkar and it works !!!!
THANK YOU !!
I have to say that I read your post at the good moment :
-I first try to buy another sp2514N HDD with the same Rev.A. I exchanged the cards but the hdd was turning but I was not able to access to it (in windows and linux, and also with the samsung boot disk estools)
-I thus decided to open the box and exchange the platters but as they are 2 platters I read on different forums that an amateur couldn't realign such platters...
-and I see your post !
The 12v TVS diode was actually shorted, thus I remove it
The 0 ohm link near the tvs diode was broken (high resistance) so I shorted it with a wire.
I saved 230Gb of data, including 15 years old family films ;-)
Thank you again !!!!!
PostPosted: August 31st, 2011, 5:02
Hi, first post here. Just to say thanks for the brilliant advice on the Diodes.. Never thought of that as a solution...
Have the same samsung disc here, that was in the same LaCie external cabinet.. It seems that the power supply is busted, so it fried the diode and the zero-link.. But fzabkar, your advice worked here too, you saved me a bundle of money, and gave me a bundle of joy in addition. My precious work was saved.. I'm very thankful.. =) (btw, i have taken a backup now.. No more chances taken with that disc.. :) )
Kind Regards
Carl Erik
Users browsing this forum: No registered users and 80 guests
