 Post subject: WD - PCB replacement + pictures
PostPosted: March 30th, 2010, 13:33
Hi All,
I have this hard drive
http://img168.imageshack.us/i/wd1p.jpg/
http://img687.imageshack.us/i/wd2l.jpg/
On the green PCB two of the chips are brunt (which easily can be seen as burnt).
I want to buy from ebay one of those of hard drives in order to swap the pcb.
What is the correct one?
http://shop.ebay.com/i.html?_nkw=WD5000 ... t=0&bkBtn=
I think that this is the best match: (not sure)
http://cgi.ebay.com/Western-Digital-WD5 ... 51916e968d
New details which I've got from a friend:
"That one has a different DCM:
http://www.harddrive-repair.com/hard-drive-parts.html
Yours is DHNNNT2AHN
The one you linked to is DBRNHT2AAN:
DCM: DBRNHT2AAN
PCB: 2061-701444-700 AD - on the barcode sticker
2060-701444-004 Rev. A on the PCB
There is contrasting info on the DCM last few (3 or 5) digits needing to be the same, but this should apply only for a head swap:
western-digital-pcb-swap-rule-t8951-20.html
Your PCB is 2061-701444-700 AD, so it is matching.
Thanks to jaclaz
What you guys think about this item?
I've got only jaclaz's opinion so I would like to get some more..
Best Regards,
 Post subject: Re: WD - PCB replacement + pictures
PostPosted: March 30th, 2010, 13:59
Will not work, PCB contains necessary info unique to the drive
PostPosted: March 30th, 2010, 14:22
Hi drc,
what is the unique info which is missing to this item?
Do you know where can I get the right pcb?
Many Thanks!
PostPosted: March 30th, 2010, 14:27
Show a picture of damages.
www.datarecoveryne.com
PostPosted: March 30th, 2010, 14:29
It's the right PCB, electronically speaking.
The word "unique" means "one of a kind", "no two the same". This is referring to the information programmed into the ROM. With this uniqueness in mind, WD has placed copies of this ROM data on the platters in firmware modules.
You CANNOT access this information without the appropriate knowledge and tools, there is no DIY solution for this.
Do not waste your money on replacement PCB's, 99% certain they will not work.
PostPosted: March 30th, 2010, 14:41
Yep, what he said.
PostPosted: March 30th, 2010, 18:17
CrazyDoctor wrote:
Hi All,
Yours is DHNNNT2AHN
DCM: DBRNHT2AAN
Thanks to jaclaz
Best Regards,
hi,
i have this PCB in stock. and be able help you program right firmware into PCB. please MSN or email me if interesting.
data recovery service[/b]
PostPosted: March 31st, 2010, 6:07
Remove the PCB and upload a photo of the component side.
If the TVS diode and fuse are damaged, then the repair will be an easy DIY.
PostPosted: March 31st, 2010, 11:31
Those are pictures of the burnt parts:
http://img405.imageshack.us/i/61707181.jpg/
http://img511.imageshack.us/i/25150457.jpg/
How can I fix that?
Best Regrads,
PostPosted: March 31st, 2010, 11:34
Possibly something you may be able to handel, I'm sure fzabkar will be able to point you in the right direction
PostPosted: March 31st, 2010, 12:23
Thanks for the quick answer.
Is it possible to take parts from a diffrent pcb?
Such WD 320 GB whereas the original PCB is WD 500 GB?
PostPosted: March 31st, 2010, 13:37
Don't see why not ;)
