 Post subject: Need Firmware module
PostPosted: March 31st, 2010, 15:11
Looking for:
Module 06 (Device Configuration)
WD2500JS-55NCB1
FW: 10.02E02
The module length should be 10?
thanks,
 Post subject: Re: Need Firmware module
PostPosted: March 31st, 2010, 16:08
Here you go
File comment: WDC WD2500JS-60NCB1-10.02E02
06.rar [1022 Bytes]
Downloaded 325 times
PostPosted: March 31st, 2010, 16:36
This drive is being very strange.
Only have Atola at my use right now so cannot check it's behavior on another device:
Drive comes in, is clicking. Click, recal attempt (the kind of rpm slowdown/speedup), repeats 3 times and spins down, then tries again a few times.
ID as HAWK, serial # XYZ etc etc.
When is see this i usually don't call it heads first, because in my experience it is often not.
First thing I do is put the PCB on a known good drive (very close in match) to see if it has the same symptoms.
It does, so first I try to transfer ROM to new PCB and see what happens.
Same results.
Now I am on to firmware.
Hot-swap grants me access to firmware map. Perform a backup and see that several of the Device config modules, as well as some other less critical modules.
Replace the unreadable modules; the only one that is not replaced is 1 Selfscan log. This is now the only module that is not readable.
Here is where it gets strange to me:
The new PCB with original ROM still clicks
The PCB from the drive I used for Hotswap does not click, but reports HAWK, etc. It DOES grant me access to SA though.
I am confused to say the least.
The only thing I can think is either there is some corruption to SA that I cannot see (maybe module is readable, but there is trash, etc)
or
Bad Head/s is causing the drive to behave oddly.
After the write of the new modules I can read them back, and verify that they where written correctly...so the write element of the head is not corrupting the data on the write attempt.
I'll report back when i figure something out.
PostPosted: March 31st, 2010, 16:42
try smart hot swap and build head map
PostPosted: March 31st, 2010, 19:14
it's easy to do. and this drive have 6 head. head map 0~5. i have same model in stock. please let me know if need any help.
data recovery service[/b]
PostPosted: April 1st, 2010, 11:41
I am sure it is easy to do when you have PC3K, but I currently do not have access to one, so I cannot rebuild headmap at this time.
Users browsing this forum: Bing [Bot], Google [Bot] and 240 guests
