 Post subject: HTT722525DLA380
PostPosted: April 2nd, 2010, 5:12
No power to HDD.
Xronis
T3 Professional Data Recovery
http://www.t3-recovery.com
 Post subject: Re: HTT722525DLA380
PostPosted: April 2nd, 2010, 12:04
Isolate heads connection, see if that makes difference
If powers on spins up then replace heads
If no,
Replace PCB, transfer external ROM and NVRAM
PostPosted: April 2nd, 2010, 18:40
AFAICS, the locking tabs for the motor connector are in the locked position.
Did you release them before withdrawing the flex lead?
BTW, is that an IDE power connector at the top RHS???
PostPosted: April 2nd, 2010, 20:11
Corrupted firmware can cause motor not to spin.
Jono
http://www.datasaversllc.com
PostPosted: April 2nd, 2010, 21:24
check the fuses on the board the black tvs
you might get lucky :)
PostPosted: April 3rd, 2010, 2:51
i guess PCB is fine. check NV-RAM
data recovery service[/b]
PostPosted: April 3rd, 2010, 7:36
Try to read the nvram and the rom.
and edit them to see if they are corrupeted. ;)
ZeBong
" Россия еще раз"
PostPosted: April 3rd, 2010, 13:13
I ran some experiments with hitachi disks editing nvram, some tests resulted in failure to power. I think you should check nvram.
PostPosted: April 4th, 2010, 13:24
Check PM
PostPosted: April 4th, 2010, 13:31
I don't think this drive has any TVS.
Xronis,
If you are still working on this drive can you provide some more info as to what you already have tried?
PostPosted: April 6th, 2010, 3:59
shortcut preamp and always "burn" the PCB NV-RAM
XRONIS
PostPosted: April 6th, 2010, 10:25
you have PM.
Users browsing this forum: No registered users and 67 guests
