Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: What's the problem of my HDD?
PostPosted: April 1st, 2010, 14:05
Ok.. cos' if I were to send to another shop to repair, it would only cost $95 (including free pick up service). The data recovery center (walking distance from my house) that charged me $160, made me wait 2 weeks to get back my data which is really long!
PostPosted: April 1st, 2010, 14:55
I'm confused. Have you had your data recovered yet or not?
PostPosted: April 1st, 2010, 15:02
It is in the process copying data from the data recovery machine :wink: But the guy said I could only collect the hard disk back next week. Does it usually take this long for a 640GB hard disk?
PostPosted: April 1st, 2010, 15:14
Oh , so u didnt get ur data back yet ? If it is in the process right now - then it should not be very long. Most likely they dont have to many imagers and u have to wait for one to get free. Also hope that their diagnostocs is correct and they wont encounter any problems when imaging ur drive. It happens u know.
PostPosted: April 1st, 2010, 17:43
And whats the chances there will be 'errors', or heads fail requiring replacement, and incurring extra costs...
PostPosted: April 1st, 2010, 19:37
i'm a bit confused. bad sectors problems require special equipment to repair or just use some software is suffice?
PostPosted: April 1st, 2010, 20:57
oh ignore my question. I googled and found out the answer :)
PostPosted: April 5th, 2010, 14:06
i saw that the technician uses the program - SpeedClone!
Anyway, wanna seek your advice, bad sectors problem can be repaired by reformatting or shall I send in the hard disk for warranty?
PostPosted: April 5th, 2010, 14:28
when u get ur data back - waranty return the drive imo.
PostPosted: April 7th, 2010, 12:05
I really need help here. I gave another external disk (1.5TB) to the guy to transfer my data onto it. I thought he would just copy the data to unused portion of the disk but he reformatted my disk! The problem is how can I get back the data that was on my disk before the reformat? I've tried Undelete Plus, Recuva and PC Inspector File Recovery. None of them helps!
Thanks!
PostPosted: April 7th, 2010, 12:09
What is overwritten is lost.
PostPosted: April 7th, 2010, 12:10
If he just formated ur drive and didnt write on it - try using R-Studio or RecoverMyFiles. If he formated ur drive and wrote on it - ur old data was overwriten and u wont get it. Sry. There are a lot of nuances to this though , how much data did u have when u gave him the drive, how much data did he write when he formated ur drive etc.
PostPosted: April 7th, 2010, 12:11
i'm trying EASEUS now.
PostPosted: April 7th, 2010, 12:13
a lot of ppl dont like easus. I use it from time to time , its not that bad, but very slow. Dont hope much for the structured recovery. Search through the RAW folder it will create for u and go by extensions. Ull lose filenames so will have toclick manually on a lot of em.
PostPosted: April 7th, 2010, 12:15
actually i only need to know the list of the files that were on the disk
cron
