 Post subject: Firmware wanted SD: WD4000AAKS-00YGA0
PostPosted: April 12th, 2010, 18:54
Looking for firmware for Western Digital WD4000AAKS-00YGA0. PCB failure on the drive.
I have in stock a WD5000AAKS-00YGA0 with matching PCB numbers, but it is not a good enough match to act as a donor. I know on older WD Silver II I could get away with using different capacity PCBs and then altering the head map. Has anyone had any luck doing something similar on more modern ROYL series drives?
Best wishes,
John
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
 Post subject: Re: Firmware wanted SD: WD4000AAKS-00YGA0
PostPosted: April 13th, 2010, 3:02
Yes, but it won't work with SD I'm afraid unless they've fixed the bug with Royl head map alteration.
You could end up with a dead PCB if you use SD on it :-(
You have PM.
PostPosted: April 13th, 2010, 17:05
You have PM.
Sean ,
they Have Version 3.6 Out Have You Tried This In That Version Also ,Its Better To Have a Backup Of The Rom in That Case ,i Am Soon Planning a tutorial Of Using rom Backups with a External ISP Programmer On HDDGURU With Adapters To Help Some New People
PostPosted: April 26th, 2010, 9:42
Hi there,
just been working on it. Used a matching WD5000AAKS PCB and altered the head map from Heads 2,3,4,5 to use heads 0,1,2,3 for the WD4000AAKS and it worked a treat.
All the best,
John
0161 408 4857
PostPosted: April 26th, 2010, 16:38
Nice one, SD have fixed the bug I assume then? :-)
Users browsing this forum: Google [Bot] and 7 guests
