 Post subject: Anyone else have a problem with Seagate Doctor 4.2?
PostPosted: January 22nd, 2010, 20:14
Version 4.2 will crash while reading a drives firmware whereas 3.0 works just fine. I've seen this with several drives now on the Barracuda choice. Anyone else have this problem?
 Post subject: Re: Anyone else have a problem with Seagate Doctor 4.2?
PostPosted: January 23rd, 2010, 1:52
Haven't used my SD tools in a long time at this point.
PostPosted: April 13th, 2010, 17:17
Well Yes ,
Also I Have Noticed 2 More Things
1 :When You Try Repair 7200.11 And 7200.12 With The Software it Juts did Not Work With The Lastest Cases I Had ,I Had To Do The Damn Thing In The Terminal
2 :When i Press Defect scan It Terminates With a Access Violation Error "Lol SD Does Not Want Us to Repair Our Drives Haa Haa Haa ." I Love PC 3000 stability :lol:
PostPosted: April 13th, 2010, 17:33
I've gone back to 3.0 as 4.2 is full of bugs.
PostPosted: April 13th, 2010, 17:39
Well ,
Agreed At Last ,Also I wAs Reading About you Having HDRC tools ,what All did You Order And How Are They Working
PostPosted: April 13th, 2010, 18:24
Your getting off topic.
PostPosted: April 13th, 2010, 18:25
Well ,
You Want Me to start another Thread :D
PostPosted: April 13th, 2010, 19:22
Yes it is buggy and can not back up and save FW. I tried on 4 drives yesterday and does not work at all. Takes long period of time to back one 1 mod and then by the time you get two the third one crashes and locks up the tool. You are right about this 4.2 version 3.0 works better.
Iorana Haraharaini
PostPosted: April 14th, 2010, 18:52
The 7200.11 buttons have never worked for me. I have always had to use terminal. Has anyone had good results with version 4.2? It really seems like 3.0 was much better and more stable.
PostPosted: April 14th, 2010, 22:18
seems a bug wa
PostPosted: April 16th, 2010, 13:33
honglake wrote:
seems a bug wa
4.2 There is always a Way To solve the Issue In a Twisted Manner Lol ,I Will Present a Case Here With the so Called Twists :lol:
PostPosted: April 16th, 2010, 15:43
Twist away...
PostPosted: April 17th, 2010, 12:39
thatdellguy wrote:
Twist away...
Yes ,
:D .Well Just One Section Of the HDD Is Now Left Before I do That .Also Planning a Small tutorial On Two Frequently Done Jobs .More To come
