 Post subject: WD5000AAKS-00V1A0 Spins up then Down again
PostPosted: April 14th, 2010, 20:04
Hey Guys/Gals im back with another hdd issue
this is a real world situation now and not me just practicing.
Today my friends WD5000AAKS-00V1A0 500GB Movie drive crashed/stopped working.
What the drive is doing is spinning up for about 1min then nothing.
when it is actually spinning its not detected in the bios or anything.
What im wondering is would a PCB swop and a U12 transplant work on this
drive if he can find a donor PCB.
Ive done this procedure on a WD 80GB and it worked like a charm but with these
newer drives im not sure... any input would be greatly appreciated as per usual
thanks guys/gals
 Post subject: Re: WD5000AAKS-00V1A0 Spins up then Down again
PostPosted: April 14th, 2010, 20:27
it's seems no the PCB problem. may be it got firmware even head problem.
data recovery service[/b]
PostPosted: April 14th, 2010, 21:30
If you can find a chip in the U12 slot. And if pcb is the problem.
PostPosted: April 15th, 2010, 1:04
networkpc3000
seems like you are correct..... but im not totally sure..... i got the exact PCB and swopped it....
powered up the HDD and got the same exact symptoms..... i did not change the firmware....
PostPosted: April 15th, 2010, 2:29
Heads problem, you will need to change the heads.
It's not a simple PCB swap.And you will not find any U12 there.
I think it's blue (-1590- or -1640-) with 2 heads, 250GB per platter side ?
PostPosted: April 15th, 2010, 8:16
unknown20010
I see U12 on the PCB if thats where the ROM data is stored on this drive thats another story... Help any one... :)
ive attached to pictures for your viewing pleasure hehheheheh
PostPosted: April 15th, 2010, 8:22
You still have to change the heads. :)
PostPosted: April 15th, 2010, 8:24
Rare case, but they do exist.
You only have to find same board which has U12 also.
www.datarecoveryne.com
PostPosted: April 15th, 2010, 8:30
He already did a PCB swap.
PostPosted: April 15th, 2010, 8:31
This is rare. Only other ROYL disk I have seen with External ROM is 2.5" Orion family. Looks like maybe some DragFly4 also use external ROM.
PostPosted: April 15th, 2010, 8:39
Dayum i knew that was coming....!! well i have NEVER did anything like swopping HSA.... so maybe i will bow out of this one.... if my friend needs that data then i will send it way.... one last question tho.... how do you match heads for these HDDs
PostPosted: April 15th, 2010, 8:45
I would try to avoid any internal work on this disk. A professional will charge you around several hundred dollars for recovery in this state, if you open the disk, even for a quick peek inside, the costs will increase to thousands.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 241 guests
