 Post subject: Seagate ST9320325AS - Momentus 5400.6 320GB No Spin
PostPosted: April 18th, 2010, 3:35
Guys ,
Have a New Case ,Its a Seagate Laptop SATA 2.5" Momentus ST9320325AS .The Drive Photos Are Here
HDA Top Side
http://i41.tinypic.com/2w5kh1l.jpg
HDA Bottom side
http://i39.tinypic.com/73lc7s.jpg
PCB Bottom Side
http://i41.tinypic.com/23s6xap.jpg
PCB Component Side
http://i41.tinypic.com/2irn2pd.jpg
Well There is No Activity In the Drive Its From a Seagate External Freeagent Family .There Is No Response From Terminal also ,I think Its a PCB Issue If the PCB Is fine then Its a Rom Issue .I Would Be Desoldering The Rom and checking The Same ,also Would Like your Feedback On this Case ,Zebong You Had This Drive Case Right ?
 Post subject: Re: Seagate ST9320325AS - Momentus 5400.6 320GB No Spin
PostPosted: April 18th, 2010, 3:57
Hi
Amarbir if it's not taking power also this might be head stuck problem open the cover and check head is at Parking site or on platters.
PostPosted: April 18th, 2010, 4:09
microsoftengineer wrote:
Hi
:D ,
When PCB Is Out From HDA then also No Terminal Response ,Head Stuck Is a Seperate Issue ,Atleast the Drive Should reach f> .In My Case No Response ,Is this a PCB ROM Failure ? Or a PCB Failure .Speaking To Few Say Its the ROM :(
PostPosted: April 18th, 2010, 7:09
did you check the fuse ?
ZeBong
" Россия еще раз"
PostPosted: April 18th, 2010, 8:40
Well ,
I Do Not Know where It Is ,But the Two SMD Components Nead the SATa Power Connector that Look Like Inductors /Resistors Were Fine With 1.6 Ohm Value .
PS :If the BIOS Is Gone Do i Have a Chance I am Hearing That the BIOS In This Is Specific To Each Drive So donor BIOS Will Not Work ,I Mean If We Could Match the Seagate HDD codes To Another HDD And Get The BIOS Its Gonna Be Wonderful .I Plan To Use A ISP Programmer and a SOIC 8 Clip To Get the BIOS contents Out From The HDD
PostPosted: April 19th, 2010, 7:56
check PM
ZeBong
" Россия еще раз"
PostPosted: April 19th, 2010, 22:35
zebong wrote:
check PM
Well ,
Zebong I See you Have Been Struggling with these too At ACE Forums .My Id there Is "therepairmasters" .Help Me Mate ,this Is Making My Head Fry
PostPosted: April 23rd, 2010, 14:14
Bump ,
Helpppppppppppppppppppppppppppppppppp :D
PostPosted: April 23rd, 2010, 22:56
Amarbir wrote:
Bump ,
I see no indication that you've actually measured any voltages.
One obvious test point would be the Vcc pin of the Winbond W9464G61H SDRAM.
Also check for voltage at the load sides of the two 2R2 coils. These form part of two switchmode regulators.
You may also want to check that the crystal is oscillating, and that there is activity on the RAM's address and data buses.
If you can find a POR pin, check that it is not holding the MCU in a reset state.
If you suspect stiction or a seized motor, then monitor the motor terminals for any activity.
Users browsing this forum: No registered users and 86 guests
