 Post subject: Hard disk gets stuck in between.
PostPosted: April 19th, 2010, 13:42
I've a seagate sata hard disk. Sometimes suddenly my pc gets stuck in between and I can hear some sound coming from the hard disk. Sometimes even my comp doesn't boot and gives an operating system not found error. On tightening the wires or by just starting the comp again after 2 or 3 hours or so the comp boots. I've noticed the problem goes away for sometime if I format my hard disk or restore the PC to an earlier stage. I want to know whether it's a hardware problem(as I can hear some sound coming from it, only when the PC gets stuck) or some software problem( as formatting and restoring helps).
Thanks and regards
Shivam Sharma
 Post subject: Re: Hard disk gets stuck in between.
PostPosted: April 19th, 2010, 13:46
RMA this drive - get new HDD
Iorana Haraharaini
PostPosted: April 19th, 2010, 13:50
Ask amarbir from this forum - he's in Chandigarh. Maybe he can handle the drive and refurbish it. Any other?
PostPosted: April 19th, 2010, 16:42
The OP has formatted the drive at least twice, so data recovery is not an issue.
Let Seagate refurbish the drive.
PostPosted: April 19th, 2010, 16:49
Not only Seagate can refurbish drives ...
PostPosted: April 19th, 2010, 20:59
yeah. many people can do it in India.
data recovery service[/b]
PostPosted: April 19th, 2010, 21:10
Seagate will do it for free, after they send you a refurbished replacement under warranty. :roll:
PostPosted: April 19th, 2010, 22:08
I don't see where OP stated his drive was under warranty
PostPosted: April 19th, 2010, 22:12
Thanks and regards
Shivam Sharma
sharma ,
Might Be the Drive Has Issues In Some Sectors And When you Access then It Creates That Noise and then Hand ,Pretty Typical ,If Under Warranty RMa the Drive To the Closest Accell "Seagate Authorised " Service Center .
