 Post subject: WD1600AAJS ATA MOD
PostPosted: April 19th, 2010, 10:41
Hi Gurus,
Does anyone have some ATA MODS for WD1600AAJS-75M0A0, DCM: HGNNHT2CG, 06 FEB 2009?
We have tried the MODS available here and on datadonor.net but cannot find a close match.
I can give more details if it helps...
regards
John - http://www.dq-int.co.uk
 Post subject: Re: WD1600AAJS ATA MOD
PostPosted: April 19th, 2010, 11:16
What version do you need?
PostPosted: April 19th, 2010, 11:34
Well our ATA MOD is corrupt so if we check version of ROM MOD 4F, it says version is 000100CS. Is this what you meant?
regards
PostPosted: April 19th, 2010, 11:59
Yep
0011.rar [136.36 KiB]
Downloaded 375 times
PostPosted: April 19th, 2010, 22:31
drc wrote:
Yep
Well ,
If I Was Him I Would Have Used This Word "thank You "
PostPosted: April 20th, 2010, 4:14
Thank you drc. We will post here when we have tried it. :)
regards
PostPosted: April 21st, 2010, 9:30
Hi drc,
That ATA MOD does not quite work. Do you have another similar one we can try?
regards
PostPosted: April 21st, 2010, 9:39
That's the only one I have that is 1.CS
PostPosted: April 21st, 2010, 9:45
Are you sure that the PCB (ROM) is original...?
PS Please place here module 12 from this HDD...
Mikippp
PostPosted: April 21st, 2010, 10:14
Thanks anyway drc. I appreciate your help.
I have attached MOD 0012 here.
Also the strange thing is that although MOD 0011 was not backed up successfully from the drive, we can see it partially downloaded and has the version number 000300E4. :?
File comment: WD1600AAJS MOD 0012
0012.zip [3.71 KiB]
Downloaded 343 times
regards
Users browsing this forum: Doomer and 235 guests
