 Post subject: wd10eads-11m2b2 Very strange bihavior, need help.(Firmware)
PostPosted: April 23rd, 2010, 11:08
Dear All,
i am working in IT infrastructure about 6 years,but never had such issue.
I am expecting very strange error with WD HDD. I have bought external elements 1 TB WDBAAU0010HBK, inside of box is wd10eads-11m2b cavian green.
Problem:
All files, after copied to a drive are corrupted. I used md5 hash utility to check source and copied file hash and it is always different. I have called to WD support, they advised me to make full format and write "0" to all sectors. This procedure took me 2 days and was successful. But after i created new NTFS partition, again all files that i copied to a drive changed their MD 5 hash sum. So i got corrupted file result again. After checking on bad blocks there was no errors, so this seems very strange.
I decided to flash modules or firmware, but WD support said there are no such things. (my suggestion is that some how, something is operating wrong with partition table)
Can you please help me to understand what can be a problem and how to fix it.
 Post subject: Re: wd10eads-11m2b2 Very strange bihavior, need help.(Firmware)
PostPosted: April 23rd, 2010, 11:41
did you compare only the md5 sums or files too ? it could be a controller or cabling problem inside the casing. if so then the best option is to rma it as no valuable data is stored on it (if i understood you correctly). for testing you could zerofill it again (only the first 10 million blocks or something like that) and use a sector edit tool to check whether they are all zeroed.
greetings
swersig
PostPosted: April 23rd, 2010, 11:55
If you can return it and get a new one, just do that. Sometimes a problem is solved easiest by just replacement.
If you can't, take the drive out, attach it directly to a sata connector inside a computer and see if you still have this issue. As swersig pointed out, it could be the circuitry inside the external case.
PostPosted: April 23rd, 2010, 12:38
I have removed drive from box, format first million and last million to zeros, that copied files again,but md 5 of files was different again.
PostPosted: April 23rd, 2010, 14:59
Noticed 1 thing, i copied small files about 15 mb. everything goes fine md 5 is equal. But when i copy big files 300m > files got currupted ...
PostPosted: April 23rd, 2010, 17:25
Found MFT is damaged, utility test disk said boot sector and backup boot sector are different and i fixed his. They are now identical, but cant fix MFT usinf test disk. Please advice software to fix MFT.
PostPosted: April 23rd, 2010, 17:55
Got this
PostPosted: April 23rd, 2010, 18:16
RMA
PostPosted: April 23rd, 2010, 18:33
RMA? Can you please give more details
PostPosted: April 23rd, 2010, 19:15
RMA = Send back the drive for replacement under warranty.
PostPosted: April 23rd, 2010, 22:59
RMA = Return Material Authorization
http://en.wikipedia.org/wiki/Return_mer ... horization
PostPosted: April 26th, 2010, 4:53
Before i will got to RMA,
I am interested, if there is a firmware for my model of HDD? wd10eads-11m2b2
Thank you.
Users browsing this forum: Google [Bot] and 73 guests
