 Post subject: PCB WD2000JD Wanted
PostPosted: April 30th, 2010, 22:41
I'm looking for a working PCB for my WD2000JD.
WD P/N: WD2000JD-22HBC0
Form Factor: 3,5"
Code on PCB: 2061-701267-001 Rev A
Code on sticker: 2061-701267-200 AL
Main controller WD70C26 - GP v2.1
Motor controller L6283 v1.3
Thank You in advance
 Post subject: Re: PCB WD2000JD Wanted
PostPosted: May 1st, 2010, 7:21
Hi, sure it's not 001267-001 on that one?
Bosse
http://www.rescue-it.se
PostPosted: May 1st, 2010, 17:36
Sorry, Bosse but I have to disagree with you.
It's the original PCB for this drive. Also 1266 and 1265 (IDE PCB) should work.
Good luck
PostPosted: May 2nd, 2010, 5:35
I have this working pcb in stock PM me for more details .
PostPosted: May 2nd, 2010, 14:17
Here is the image of the burnt chip L6283.
PostPosted: May 2nd, 2010, 21:06
hi,
it's the PCB fix for you need. i have it in stock.
http://gotbackdata.com/Upimg/photos/lar ... 20REVA.jpg
data recovery service[/b]
PostPosted: May 3rd, 2010, 20:33
I have the 2061-701267-001 Rev A PCB not the -001267 I think that will make a difference.
PostPosted: May 6th, 2010, 4:02
2061-701267 SATA = 2061-701265 PATA + rewrite flash :D .
Users browsing this forum: No registered users and 81 guests
