 Post subject: ST L6283 1.3 Motor controller
PostPosted: April 30th, 2010, 22:42
Does anyone know where I can get this chip? The one on the PCB I have is burnt up. If I replace this chip, will the HD work again?
 Post subject: Re: ST L6283 1.3 Motor controller
PostPosted: April 30th, 2010, 23:47
Normally it is better to change out pcb board on this one. Why not tell us what drive and ID on this one it is easier to advise you on it. Post your drive here so we can help you out a little better on this one.
Iorana Haraharaini
PostPosted: May 2nd, 2010, 10:40
Western Digital Caviar SE
WD2000JD-22HBC0
PCB # 2060-701267-001 Rev A
PostPosted: May 2nd, 2010, 11:04
I dont think this IC would be commonly availabe on any store , you can get it from same pcb or marvell pcb also uses the same IC .
PostPosted: May 2nd, 2010, 12:22
Not available commonly even if I have them, but 90% there's not only the L6xxx chip gone in the PCB. According to what happened, there's 20-30% probability of preamp damage too (internal problem) - this must be pointed out before changing PCB or attempting repair otherwise you'll have another chip damaged or another complete FUBAR pcb in seconds...
PostPosted: May 3rd, 2010, 9:29
Actually, you can get motor controller chips from www.getchips.com
www.datarecoveryne.com
Users browsing this forum: Majestic-12 [Bot] and 80 guests
