 Post subject: Samsung HD400LJ
PostPosted: May 4th, 2010, 1:27
hi
i have this hdd with bad pcb and i have few dozen of other samsung.can anyone tell me if i can replace pcb from another model,assuming i replace also the controler.thank you
 Post subject: Re: Samsung HD400LJ
PostPosted: May 4th, 2010, 1:31
Post a pic of both (bad) PCB and the donor PCB.
PostPosted: May 4th, 2010, 2:08
If the PCB is from EXACT drive (but must be EXACT in FW, ROM version, FW on platters and most of all INTERNAL CONFIGURATION) it can work, otherwise NO.
Assuming you know all the three things above, we can make the PCB compatible or it is possible to recover data from drive even if the original PCB is lost.
Users browsing this forum: Bing [Bot] and 63 guests
