 Post subject: How to remove Hitachi Travelstar HDD platter.
PostPosted: May 3rd, 2010, 23:48
l'm have a spolit Hitachi IDE travelstar model, HTS541040G9AT00.
l suspect it the read write head that giving problem.
How do l remove the platter from it, to do a data recovery on a identical working drive.
l tried to remove the platter but it was obstruct by the read/write head arm at around 5 o'clock position.
Anybody have successfully remove it before ?
Please advise.
Thanks....
Regards.
 Post subject: Re: How to remove Hitachi Travelstar HDD platter.
PostPosted: May 4th, 2010, 1:36
PostPosted: May 4th, 2010, 2:12
"Anybody have successfully remove it before ?"
Everytime a travelstar comes and need platter swap.
I am sure you are doing it in clean room, with demagnetized equipment and clean room gloves, and you have successfully parked and removed head without scoring the platter.... aren't you ?
PostPosted: May 4th, 2010, 2:58
WTF????
Another "one size fits all" solution.
Why on earth are you trying to remove the platter when you yourself suspect heads?
So, if you successfully diagnose yourself with a headache you put a plaster on your toe, right?
(Before anyone starts moaning about "flaming" noobies, then sorry but this guy has clearly ploughed straight in without asking any advice and probably already destroyed his drive.)
PostPosted: May 4th, 2010, 3:58
Anybody have successfully ..............
Please advise.
Thanks....
Regards.
This is a good start on making your HDD clock now for you. All you need is some nice light and it is saying 5 o'clock. Now you can get one time zone from here.
Yes successfull stories on how to make a HDD clock exist this one is about all you are good for now the way your are going.
I am sure this is not a clean room job or it is on a clean kitchen table.
Sorry but this one is too far gone now.
Iorana Haraharaini
PostPosted: May 4th, 2010, 9:43
pcimage wrote:
WTF????
=)) U are safe =) I cant touch this , not with the amazing OP post =)
PostPosted: May 4th, 2010, 10:29
Pliers. If it is really stubborn you might have to break out the hammer too.
PostPosted: May 4th, 2010, 10:53
Please advise.
Thanks....
Regards.
The game is over allready.
I can do the recovery for you, but don't expect cheap quote after this "action"...
Janos
PostPosted: May 4th, 2010, 10:57
Hmm, 5 o'clock is a nice time to have a little tee and biscuits. :D
PostPosted: May 4th, 2010, 12:26
Have a look at the platter you will see the problem ;)
https://www.mjm.co.uk/
PostPosted: May 4th, 2010, 12:31
:mrgreen: Exactly! :D
Users browsing this forum: Bing [Bot] and 328 guests
