 Post subject: Fujitsu 2.5" show "Restricted Mode!"
PostPosted: April 2nd, 2010, 23:47
Hi
I has Fujitsu 2.5" hdd MHX2300BT AND MHW2120BH
When i connect it to UDMA,Then UDMA display
Restricter Mode!
Can anyone to tell me , What fault on hdd and How to solve this problem.
many thank for you
 Post subject: Re: Fujitsu 2.5" show "Restricted Mode!"
PostPosted: April 3rd, 2010, 5:56
HI
connect Terminal to it and try.
PostPosted: April 6th, 2010, 2:35
Thank itconcept
I has connect the Terminal.
and i has test another Fujitsu hdd and test is ok no "Restricter Mode!"
message display.
So I connect the hdd to pc3000 is ok.
Can anyone get me a little suggestion.
many thanx!
PostPosted: May 6th, 2010, 15:22
Restricted mode on newer Fujitsu drives usually indicates a bad head.
