 Post subject: Seagate Barracuda 0 sectors
PostPosted: May 7th, 2010, 8:46
Hi, I've got a problem with my Seagate Barracuda 7200.12 (ST3500418AS).
I've replaced the PCB with an identical one from a working HDD (same PCB, same firmware version) because the old PCB, burned out due to wrong power input (inside an external HDD case).
Even with the new PCB the drive is not recognized by BIOS and is not recognized by the operating system.
The linux kernel detect the disk but show me only few informations:
ata5.00: configured for UDMA/66
ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata3.00: failed to read native max address (err_mask=0x1)
ata3.00: HPA support seems broken, skipping HPA handling
ata3.00: ATA-8: ST3500410AS, CC34, max UDMA/133
ata3.00: 0 sectors, multi 0: LBA NCQ (depth 0/32)
ata3.00: configured for UDMA/133 (device error ignored)
scsi 2:0:0:0: Direct-Access     ATA      ST3500410AS      CC34 PQ: 0 ANSI: 5
sd 2:0:0:0: Attached scsi generic sg0 type 0
sd 2:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 2:0:0:0: [sda] Attached SCSI disk
I tought to execute the procedure linked here: tutorial-resolve-lba-seagate-7200-bios-don-recognize-t11040.html
But with this procedure, can I keep all my data without loss nothing?
 Post subject: Re: Seagate Barracuda 0 sectors
PostPosted: May 11th, 2010, 22:52
Does the damage to the original board look anything like that in the lower RH corner of this PCB?
http://i44.tinypic.com/jj4ks8.jpg
If so, then there may be a simple DIY fix.
PostPosted: May 12th, 2010, 1:24
Did you transfer the original ROM ?
It's 7200.12 NOT 11. That will not work with your 7200.12
PostPosted: May 12th, 2010, 9:42
You can't just replace the PCB on these, they are unique to the drive.
PostPosted: May 13th, 2010, 14:32
Not true. Same drive architecture in 7200.11 and 7200.12. Same procedure for 0 lba has worked many times for us.
PostPosted: May 14th, 2010, 8:54
YOU NEED TO TRANSFER THE ROM FROM ORIGINAL PCB ONTO THE NEW PCB FOR IT TO FUNCTION WITH THIS DRIVE.
PostPosted: May 16th, 2010, 9:15
You sure ? :!:
PostPosted: May 17th, 2010, 10:02
I bet he does not sure.
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: May 17th, 2010, 22:13
may be the true 0LBA problem as you think. and you should have more experience if you done many with .11 .12. you should understand what i said
data recovery service[/b]
PostPosted: May 18th, 2010, 3:59
The commands are still the same, as is the fault. Maybe it just has different cause of the failure...
Users browsing this forum: No registered users and 140 guests
