 Post subject: maxtor hard drive main logic board running hot
PostPosted: May 9th, 2010, 22:50
hi guys i wonder if someone can give me some advice.
sister daughter pc system went down and it contains all her projects and school work.
the problem with the drive is that the main pcb board is running a little bit to hot.
and its not picking up in the bios at all.
there is no clicking sound.
i dont think its a motor problem as there is no beeping noise
the problem could be a short on the board somewhere.
allso not sure if the preamp could be shorting out this might be causing the drive to run hot.
what im trying to find out is it possible to swap the old rom located on this board somewhere
onto another working board.
can someone point me to the right rom in the photos
or possible give me some ideas to check it out first.
voltages etc
cheers all
enclose is the photos
 Post subject: Re: maxtor hard drive main logic board running hot
PostPosted: May 9th, 2010, 23:09
Maxtor PCBs are easy... no offense but if you consider yourself to be a DR tech you should know how to do it already (or at least know how to figure it out)
PostPosted: May 9th, 2010, 23:37
Is this drive being detected in the BIOS? Your DIY skills sound like they have the potential to kill all chance.
Zero Alpha: zeroalpha.com.au
PostPosted: May 10th, 2010, 0:35
hmmm well i wanted advice on where the rom is located.
all i want to know is where the rom is located for a straight transfer.
DIY skills dont make me laugh on the floor. :mrgreen:
thanks
PostPosted: May 10th, 2010, 1:26
U303 is the ROM.
Rgds
www.datasave.ro
PostPosted: May 10th, 2010, 6:16
ccc thank you for your help
:beer: :beer:
Users browsing this forum: No registered users and 68 guests
