 Post subject: Samsung 80GB IDE PCB Burn
PostPosted: May 11th, 2010, 6:28
I have just received an SAMSUNG 80GB IDE 820N Drive, attempted repair of PCB previously, I have swap the PCB, drive spin up normally when it comes to reading it just stop spining ? any idea does the PCB is not matchecd ?
RAID/Server Recovery
 Post subject: Re: Samsung 80GB IDE PCB Burn
PostPosted: May 11th, 2010, 6:55
Are you performing data recovery for customers as a service? You seem to ask many basic questions about many different disks.
Maybe you need to post the terminal log here, might be a bit more helpful.
PostPosted: May 11th, 2010, 7:14
820N is not the model. Maybe SP0802N or SP0822N ?
PCB swap doesn't work.
P.S. HDDGUY is right :D
PostPosted: May 11th, 2010, 7:16
SP0802N is the model,
PostPosted: May 11th, 2010, 7:20
OK then diagnose it.
PostPosted: May 11th, 2010, 7:30
thanks for the inspiration but i do appreciate for little help
PostPosted: May 11th, 2010, 7:46
you probably use the wrong PCB. Send it to a pro
PostPosted: May 11th, 2010, 8:06
I would appreciate even more a PayPal donation... more than a thing to say is a procedure to learn, job to do and finally money to earn.
PostPosted: May 12th, 2010, 20:49
Pcb mis match , PM me .
PostPosted: May 14th, 2010, 9:05
DEFINATELY PCB MISMATCH
TRY MATCHING ONE
PostPosted: May 14th, 2010, 10:31
... or make it compatible :D
(Oh yes it is possible, but you have to study a li'l bit...)
PostPosted: May 17th, 2010, 10:11
Don't try to swap PCB, no need.
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
Users browsing this forum: Google [Bot] and 106 guests
