 Post subject: PCB for WD1600JS
PostPosted: May 22nd, 2010, 13:16
need a PCB for a WD1600JS-60NCB1 the firmware I think is HSBANT2CA. the old board is burnt. any help would be great.
 Post subject: Re: PCB for WD1600JS
PostPosted: May 22nd, 2010, 15:31
You can not just swap boards on this one. There is more to it than a simple pcb swap on this one
Iorana Haraharaini
PostPosted: May 22nd, 2010, 23:45
If you upload a detailed photo, one of us may be able to help you repair your board. Many times the problem is only a shorted diode, in which case it can simply be removed. There may also be an open fuse or resistor.
Good luck.
PostPosted: May 23rd, 2010, 1:10
It's the DCM not the FW.
You have to transfer the original ROM to the new PCB. Your PCB # would be 1335-005 or 1393, I can't remember exactly.
2nd option : send it to a pro.
Good luck
PostPosted: May 23rd, 2010, 1:31
here is demo video for show you how to swap original ROM chip to good PCB.
http://www.youtube.com/watch?v=X2hgiDHiXKM
data recovery service[/b]
Users browsing this forum: No registered users and 162 guests
