 Post subject: Wd200jd Can't start
PostPosted: May 25th, 2010, 7:21
Wd200jd can't start, making strange sounds like inside engine can't start
Any suggestions?
 Post subject: Re: Wd200jd Can't start
PostPosted: May 25th, 2010, 7:24
Yes, contact the nearest pro.
PostPosted: May 25th, 2010, 7:25
Sounds like failed motor chip, you have to replace SMOOTH chip (L6283 1.3) and your drive (MAY) spin up fine. ( I hope so )
OR
you can change the entire PCB and transfer the original ROM.
Good luck
PostPosted: May 25th, 2010, 7:34
If it's not the PCB it will need internal work which isn't a DIY job. Has it been dropped at all?
Leigh
DataWreck Data Recovery Services
www.DataWreck.co.uk
PostPosted: May 25th, 2010, 12:24
found on ebay " 1pcs of Smooth L6283 1.3 HDD Motor Combo IC for Western Digital Hard Disk Drive."
is this the right chip?
pcb no so easy to get
maybe any other suggestion?
PostPosted: May 25th, 2010, 12:33
PostPosted: May 25th, 2010, 12:51
maybe any !!othe!!r suggestion?
PostPosted: May 25th, 2010, 13:03
No, motor problems are not DIYable
PostPosted: May 25th, 2010, 14:10
where so exactly the problem if not pcb?
maybe try something like this? http://www.youtube.com/watch?v=uIPZtJyr ... re=related
PostPosted: May 25th, 2010, 14:13
Sure, if you want to lose the data (and the drive)
PostPosted: May 26th, 2010, 8:52
The advice here is to get assistance from a professional who has a very good chance of retrieving your data.
though I suspect you are going to avoid this advice and attempt your own repair in which case you will have yourself a new doorstop.
you have recieved good advice. If its bad advice you want then maybe you should head back over to youtube - the elephants graveyard of DIY attempts....
PostPosted: May 26th, 2010, 8:59
HDDGUY is awarded "QUOTE OF THE WEEK" and "STALLION FOR A DAY" for this definition.
:beer:
PostPosted: May 26th, 2010, 9:43
:beer:
Agree. :D
@ al3x: can you post a sound clip to make us know exactly what's wrong with your drive ?
PostPosted: May 27th, 2010, 17:25
nevermind , just wanted to check DIY possibility
yeah, sure sund clip, maybe i'll record some hours and you'll recover some data based on it?
PostPosted: May 27th, 2010, 19:32
what model of PCB you have? but first is post the sound of your drive. perhaps it's no the PCB problem.
data recovery service[/b]
PostPosted: May 30th, 2010, 9:02
You misunderstood me, I meen sound clip for the strange sounds.
Users browsing this forum: Bing [Bot] and 203 guests
