 Post subject: Help with WD2500BEVT
PostPosted: June 2nd, 2010, 9:31
Hi
I will need help with this drive.
WD2500BEVT-00ZCT0
When I connect to WD Doctor and power this drive show ready. There is a few clicks before that.
Load from HDD, I try Black I and Royl, Low Speed, disk cannot be recognized and status is now error.
Back up FW, there are no modules but i can see all tracks. I scan all tracks and all of them are OK.
Under Black I shows head map 0 1 2 and under Royl 0 1 2 3 , Reading ROM completed.
I do Read/Write test and report says 0 and 1 head read-only.
If it is FW issue did someone have it or what I need to do next?
Thanks.
Sistrum Data Recovery
http://www.sistrum.mk/en
 Post subject: Re: Help with WD2500BEVT
PostPosted: June 2nd, 2010, 9:36
After this few clicks is your drive spindown ?
PostPosted: June 2nd, 2010, 9:53
Yes spin down.
When I click on load from HDD start spinning again, few clicks and spin down.
PostPosted: June 3rd, 2010, 23:43
Any idea, advice?
This hard drive is still on my desk :D
PostPosted: June 4th, 2010, 11:20
Kum Ruzvelt wrote:
Any idea, advice?
This drive have head problem.
you should replace MHA and do alignment, if you can...
If you need, i can help...
Janos
PostPosted: June 4th, 2010, 23:13
Thanks Janos,
I will start looking for donor drive.
Users browsing this forum: No registered users and 0 guests
