 Post subject: EMTEC 1GB
PostPosted: June 2nd, 2010, 15:40
I've got flash drive that has partially damaged PCB (close to USB plug). I don't know model name of it.
I'm looking for PCB photo (both sides) of this drive.
I've seen somewhere similar one, but 2GB. It was C150B model.
data recovery Poland
 Post subject: Re: EMTEC 1GB
PostPosted: June 2nd, 2010, 16:13
Put your photo. What controller?
PostPosted: June 2nd, 2010, 16:42
Yeah, if you post a photo of what you have, that would help
PostPosted: June 3rd, 2010, 6:38
Controller UT163. Someone bend it and then tried to repair it.
Don't know where to connect second and third pin (USB plug to pcb).
PostPosted: June 3rd, 2010, 6:49
Looks like all element on place. Is pen recognize by OS?
If not, you should read flash directly form nand.
PostPosted: June 3rd, 2010, 8:51
Here is a datasheet for the controller:
http://booroo.ru/wp-content/uploads/files/UT163.pdf
It looks like pins 8 and 9 are the USB D+ and D- pins, respectively.
PostPosted: June 3rd, 2010, 12:05
It's not recognized by OS nor ChipGenius, but the led on it is on (red).
8 and 9. Thanks. I thought so. I'll try and let you know.
PostPosted: June 4th, 2010, 2:26
Drive is working. Thanks.
