Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: Seagate 7200.12
PostPosted: February 26th, 2010, 8:56
Hi to all,
Anyone knows this error:
Rst 0x10M
No HOST FIS-ReadyStatusFlags 2002B001
ASCII Diag mode
F3 T>/1
F3 1>N1
ExecuteSpinRequest
HighPowerMode
Failed to load overlay 00000004
LED:000000CC FAddr:0028958
Rst 0x10M
Thanks in advanced,
ZeBong
" Россия еще раз"
 Post subject: Re: Seagate 7200.12
PostPosted: March 2nd, 2010, 13:59
Did You got solution? Dommer & pepe pls. help.
PostPosted: March 25th, 2010, 6:00
i also problem but this family
pcb is not correct and original
i tested this model hdd with other pcb and rom in this family
but with original pcb
No HOST FIS-ReadyStatusFlags 2002A1A5
and then 2>U , 1>N1
smart failure
and terminal hang on
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: March 25th, 2010, 6:21
are you test sn hdd in terminal?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: June 5th, 2010, 12:04
Hi, I have a CC37 firmware, 7200.12 500GB.. HDD not getting detected in BIOS. tried to fix it with BSY fix method but no go... first i get : Rst 0x10M
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
but then afetr ctrl+z i get the F3 T>
can do a spin down U & spin up with no errors Z, but when i send the F3 1>N1 command it starts throwing up the error: Failed to load overlay 00000005 LED:000000CC FAddr:00289581& keeps repeating the same thing. For :
F3 T>m0,2,2,0,0,0,0,22
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 0025633
B, File Error 000000D0
any other coonad i put in it again gives me Failed to load overlay 00000005 error...
Kindly let me me know if there is a way to fix my HDD. I need the data inside it. PLEASE HELP...
PostPosted: June 5th, 2010, 12:15
Seek pro service on this one, before you destroy it completely.
PostPosted: June 5th, 2010, 23:48
lol
Zero Alpha: zeroalpha.com.au
PostPosted: June 6th, 2010, 0:52
@ Zero Alpha : LOL!!! whatz so funny in it???
PostPosted: June 6th, 2010, 4:01
take this to a pro your going to kill your data.
PostPosted: June 6th, 2010, 8:04
thanks for the advice mate... so u won't be able to help me...
PostPosted: June 6th, 2010, 8:55
you need knowledge and tools to solve this and thats not going to happen instantly in a few posts. thats why a few members have encouraged you to seek professional help. good luck i hope a pro can help you because it sounds like its going to be a tough case and something that you have probably contributed too.
PostPosted: June 6th, 2010, 10:21
@Zero Alpha : hey mate.. :) i had been to a pro & its gonna cost me a fortune to get the data so i was hopin if u guys can guide me... have been followin ur posts & u guys are pro's & have ample amount of knowledge on HDD's... i'm using a DKU-5 as a TTL & followed the instructions gradius had posted for the bsy fix... & posted the o/p... i would surely wanna learn if u guys can spare a lil time & guide me...
PostPosted: June 6th, 2010, 22:29
PostPosted: June 8th, 2010, 13:35
Hi...
What tools will i be needing to get the drive up???
PostPosted: July 22nd, 2010, 1:52
I just successfully repaired one of these drives. What I did was this...
First I removed the PCB and issued the spin down command /2 then Z
Then I put the PCB back onto the drive and spun it up "U"
I then cleared the G-List with the m0,2,2,0,0,0,0,22 command
The drive came ready then I cleared the SMART with the N1 command. The drive now works fine.
PostPosted: July 22nd, 2010, 3:23
"m0,2,2,0,0,0,0,22" doesn't clear the G-List.
In any case that wouldn't help a drive load it's firmware overlays.
PostPosted: July 22nd, 2010, 4:16
My bad, translator rebuild. That did fix this problem.
PostPosted: July 23rd, 2010, 3:48
hi digitalrecoveryNZ.. :)
How do you do that??? can u please help???
PostPosted: July 23rd, 2010, 5:01
Hi Elish,
Just try what I stated in my previous post about removing the PCB etc. Translator rebuilt is the "m0,2,2,0,0,0,0,22" command.
PostPosted: July 23rd, 2010, 9:09
digitalrecoveryNZ - (your diagnosis is bad!! and this means you are wrong)
a. your patient was probably not same as elish.
b. your problem was CERTAINLY not the same as elish.
So you give elish a solution to repair a broken heart when elish has a broken leg.
digitalrecoveryNZ - if you were a doctor - you would be dead mate :mrgreen:
