Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: SEAGATE 500 GB H.D.D NOT DETECTING IN BIOS
PostPosted: June 9th, 2010, 10:55
SEAGATE 500 GB H.D.D NOT DETECTING IN BIOS AND IT HANGS THE PC.
ALSO AFTER OPENING UP I FOUND THAT THE SMOOTH IC (AS WRITTEN ON THE IC'S) IS LITTLE BIT HOTTER THE OTHER IC'S. HOW CAN I FIND THE BAD COMPONENT.
SEAGATE BARRACUDA 7200.11 500 GB
ST3500320AS(B)
http://i46.tinypic.com/25086cz.jpg
 Post subject: Re: SEAGATE 500 GB H.D.D NOT DETECTING IN BIOS
PostPosted: June 9th, 2010, 15:46
HI
check if the Drive is taking power and Rotating normally without any strange sound it means normal lock issue what happens to it fall down ?
PostPosted: June 9th, 2010, 16:05
PROBLEM EXISTS BETWEEN KEYBOARD AND CHAIR
PostPosted: June 9th, 2010, 16:45
You mean a "gasket" between keyboard and a chair?
www.datarecoveryne.com
PostPosted: June 9th, 2010, 17:46
haha, love it!
Perhaps we can call it the "H.I.G. Module" - Human Interface Gasket?
Data Recovery Ireland
PostPosted: June 9th, 2010, 17:48
LOL
ZeBong
" Россия еще раз"
PostPosted: June 9th, 2010, 18:22
O.K you have access to the "inner sanctum".(no not the S&M site)
The IC can be removed by placing the PCB on a upside down iron set to "wool" , please remember to plug the iron in.
Universal Declaration of Human Rights: Article 19
PostPosted: June 10th, 2010, 6:52
Your drive may be afflicted with the BSY firmware bug.
See this thread:
http://forums.seagate.com/t5/ATA-and-Se ... 036#M19464
PostPosted: June 10th, 2010, 8:13
@fzabkar , if so it should ID it self in Bios with the right name but with 0mb...
Bosse
http://www.rescue-it.se
PostPosted: June 10th, 2010, 8:36
If I connect this hdd, and i try to enter the cmos setup ultility it hangs and if comes doesn't show up the hdd.
The drive is spinning ok and there are no sounds
I would rather buy a new h.d.d then buy a logic board.
please tell how to check for all the necessary voltages on this logic board.
PostPosted: June 10th, 2010, 8:52
drc, whats the meaning of PROBLEM EXISTS BETWEEN KEYBOARD AND CHAIR
PostPosted: June 10th, 2010, 10:38
This was meant to be an insult to you, so ignore it. The correct solution has been provided to you in fzabkar post. Follow the suggested links.
PostPosted: June 10th, 2010, 10:40
Bosse
This is not always the case. Depends upon the BIOS.
PostPosted: June 10th, 2010, 11:06
It was meant to indicate that the problem is not with the PCB, but with the person who is assuming that something needs to be done to/with the pcb instead of taking thirty seconds to search the forum or the internet for one of the 100000000000000000000+ threads about this same problem
PostPosted: June 10th, 2010, 16:46
Bosse
http://sites.google.com/site/seagatefix/Home
"These are instructions for fixing a Seagate 7200.11 hard drive that is stuck in the BSY state. This can be determined by the fact that it won't be recognized by the computer's BIOS. If your drive is detected, but shows up as a size of 0, then you're drive has a different problem and these instructions will not apply."
PostPosted: June 12th, 2010, 10:42
i tried this method but now I cannot enter any commands via putty
please help. the ttl to serial converter is ok
PostPosted: June 12th, 2010, 20:12
How do you know the adapter is working?
If you connect the Tx and Rx wires together, can you see characters being echoed on your screen when you type? If so, and if you now separate the Tx and Rx wires, can you still see echos when you type?
PostPosted: June 16th, 2010, 8:27
I HAVE USED THIS CIRCUIT ..
http://freecircuitdiagram.com/2009/03/2 ... ransistor/.
IF THAT DOESN'T WORK CAN I USE THIS ...
1) http://ireckon.net/2009/05/unbricking-a ... barracuda/
2) http://www.msfn.org/board/topic/128807- ... 0011-hdds/
PostPosted: June 16th, 2010, 19:00
coolday wrote:
I don't believe your two-transistor circuit will work. AIUI, the "TTL" logic is not 0-5V. The MCU Vcore is 1.2V and its Vio rail would be 2.5 or 3.3V. This means that the drive's TxD signal will not be able to turn off Q1. If you want to adapt this simple circuit, you would need to power it from the drive's Vio rail. Suitable connection points may be the SDRAM or EEPROM power pins, or a more accessible location such as a capacitor or coil in the associated switchmode regulator. You can confirm the voltage level by measuring the remaining pin at the serial connector. This pin will be pulled up to the supply via a resistor.
If you are not comfortable with the above, then a USB Nokia cable would be a non-intrusive alternative.
