Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Need Help Saegate Barracuda ST31000333AS 7200.11 Hard Disk
PostPosted: June 16th, 2010, 15:08
AlterEgo, Ill buy your donor board! I need it to fix a 1.5 TB Seagate... someone plugged in an 18 V power supply into to it and fried a portable drive... the PCB is melted, hoping to get the data back...
PostPosted: June 16th, 2010, 19:19
The usual culprit is a shorted TVS diode. If you are lucky, then simply removing this diode will be enough to get your drive running again.
See this article for help in identifying the components:
http://hddscan.com/doc/HDD_from_inside.html
If you are still unsure, upload a detailed photo and one of us will help you.
Users browsing this forum: No registered users and 237 guests
