 Post subject: Logic Board Failed WD5000AAJB-00YRA0
PostPosted: June 28th, 2010, 17:05
Western Digital
WD5000AAJB-00YRA0
WD Caviar SE
MDL: WD5000AAJB-00YRA0
Date: 27 Nov 2007
DCM: DHNNHT2AHB
WWN: 50014EE2561D25B5
Drive Parameters:
LBA 976773168
I think the logic board has failed on this drive.
The drive spins up and seems to make no bad sounds.
Any thoughts on how to proceed with repair/data recovery?
 Post subject: Re: Logic Board Failed WD5000AAJB-00YRA0
PostPosted: June 28th, 2010, 17:06
Get a real diagnosis would be my first suggestion
PostPosted: June 28th, 2010, 17:52
A drive that spins up but doesn't detect in BIOS will usually not have a PCB fault. That said, if replacing the PCB, be prepared to transplant an 8-pin serial EEPROM chip from patient to donor. This IC contains unique drive specific calibration data. If you need help in identifying the parts, upload a detailed photo.
PostPosted: June 28th, 2010, 21:11
Don't have one in front of me right now, but I don't think this drive has one.
PostPosted: June 29th, 2010, 11:37
You are right, this one does not have one.
As to original post: it does not sound like PCB problem
www.datarecoveryne.com
PostPosted: June 29th, 2010, 12:17
No EEPROM on this drive.
Is there a very faint ticking noise? I have seen a number of these with SA problems that behave that way.
Chris
PostPosted: June 30th, 2010, 12:40
Probably SA.
PostPosted: July 1st, 2010, 9:53
Russwinters wrote:
Probably SA.
I would say almost certainly SA. Especially if disk remains powered.
PostPosted: July 1st, 2010, 10:16
Should have been :
That said, be prepared to transplant an SA - as there's no 8-pin serial EEPROM chip - from patient to donor. This SA contains unique drive specific calibration data. If you need help in solving the problem, send it to a pro.
:mrgreen:
P.S. I would check heads too... "AAJB-00YRA0" ......
Users browsing this forum: No registered users and 370 guests
