 Post subject: WD Caviar disk - U12 swap, better, but not quite there
PostPosted: July 3rd, 2010, 6:04
I was wondering if someone could give me a pointer as to what the problem might be here - I have an inkling the u2 might be damaged, but don't know. It's on a WD1600 (Caviar SE).
At first the 160GB disk board had been blown up in what seems to be the usual way by a power surge (which also blew the psu). Swapped the PCB from a donor, got the 8GB hawk in bios. Proceeded to swap the U12. The first time I booted it, it was recognised correctly as 160GB and I got as far as seeing the directories on the disk, so it was mounted. I couldn't see any files when I tried to copy some off though. So tried rebooting (bad idea).
Since I rebooted and ever since, the drive will get recognised by the BIOS, but it won't mount. In linux, this looks like:
res 51/04:08:00:00:00.00:00:00:00:00/f0 Emask 0x1 (device error)
ata3.01 status: { DRDY ERR }
ata3.01 error: {ABRT }
ata3.00: configured for UDMA/133
ata3.01: configured for UDMA/133
ata3: EH complete
ata3.01: exception Emas 0x0 SAct 0x0 SErr 0x0 action 0x0
ata3.01: BMDMA stat 0x65
ata3.01: cmd c8/00:08:00:00:00/00:00:00:00:00/f0 tag 0 dma 4096 in
(don't know if anyone can decipher that)
So I guess my questions are:
Has anyone seen this before, is it likely to be a knackered U12, even though it is still detected correctly by the bios? (is it a case of 'if it's dead it's dead', or can it be partially dead?)
How easy is it to find a donor board with the correct U12 info from another disk (unlikely I guess, but what needs to match? I've tried 2 or 3 with no success.)
Thanks if anyone can provide any pointers. The data isn't really important enough to go for a pro option, but it would be nice to tinker enough to get it off. Thanks.
 Post subject: Re: WD Caviar disk - U12 swap, better, but not quite there
PostPosted: July 3rd, 2010, 6:34
Whoops, I mean U12, not talking about a band ;)
PostPosted: July 3rd, 2010, 8:14
In fact there's another problem elsewhere. Turn on PC3k...
PostPosted: July 3rd, 2010, 10:02
Hmmmm, I don't have access to any of that kit. Unless anyone has any other ideas, I guess it's game over for this one :oops:
PostPosted: July 3rd, 2010, 10:28
Post on WD FORUM and ask if someone will give the info you need without tools assuming you can interact with internal fw. - not likely...
Option "b" : ask for pro intervention, that should be in the low end of price table.
PostPosted: July 4th, 2010, 6:42
Is it possible to find a donor that works without a u12 swap if I try enough? I can probably get hold of quite a few of them. What are the odds?
PostPosted: July 4th, 2010, 7:04
That won't work and / or corrupt ROM or SA (more rare but happens).
PostPosted: July 4th, 2010, 16:39
Fair enough - just thought I'd seen people in this forum before say they've occasionally managed to swap a board without needing to swap the u12?
PostPosted: July 5th, 2010, 0:23
Fair? You still have to get data...
PostPosted: July 5th, 2010, 8:32
Sorry, not sure I understand - you are saying there is still a possibility for me to get the data alone or not?
PostPosted: July 5th, 2010, 13:07
When I use mhdd I just get !!!!!!! (abrt errors) for every sector of the disk. I guess this means a probable corrupt SA? The thing that puzzles me is that it worked the first time I booted it after transplanting the U12. Is it possible that the PCB from a different disk has corrupted the SA? Why would it work once then never again? Strange.
PostPosted: July 5th, 2010, 13:28
I vote for SA mod damage on this one. You need PC3K to fix this one. You can not do anymore now on your own. Sorry.
Iorana Haraharaini
Users browsing this forum: Google [Bot] and 230 guests
