 Post subject: fujitsu MHT2040 not detected
PostPosted: July 6th, 2010, 3:09
Hello
We have problem, fujitsu drive is not detected in MHDD anyhow.
We hear calibration, but nothing in MHDD.
no BUSY, no DRSC, no AMNF
Can be problem PCB or is it SA?
 Post subject: Re: fujitsu MHT2040 not detected
PostPosted: July 6th, 2010, 4:00
I wouldn't think it was the SA on this one. I am not aware of ever seeing one spin and show nothing on the Status/Error registers.
PostPosted: July 6th, 2010, 4:30
Yes can happen, instead.
Typical : at startup is BSY, after calibration or partial calibration, nothing.
If "no register" activity at all, I would check the interface section.
PostPosted: July 6th, 2010, 5:22
There is no BSY also
PostPosted: July 6th, 2010, 5:33
If you can exclude cabling problem or configuration, then electronics are first suspected part.
PostPosted: July 6th, 2010, 6:01
If the drive spins up and no sign of ata registers then :
No other options.
PostPosted: July 6th, 2010, 7:33
:mrgreen:
PostPosted: July 6th, 2010, 7:49
The drive is calibrating but about 5 seconds after spin up
Users browsing this forum: Majestic-12 [Bot] and 266 guests
