 Post subject: Solid State Drives
PostPosted: July 13th, 2010, 16:26
Hi gurus,
What are solid state drives, how they works, good and bad things ?
thank you
RAID/Server Recovery
 Post subject: Re: Solid State Drives
PostPosted: July 13th, 2010, 17:58
Solid state drives are just that. No moving parts. Most use NAND flash which is a type of memory technology. Most have 10 or more years data retention because of wear leveling and general use considerations. Solid state is not appropriate for everything ( i.e. Swap files, etc.).
HWHacker
Smiles
PostPosted: July 13th, 2010, 18:31
Consider it to be very much like a Nand-Flash USB stick but:
1. It has a different interface, SATA,IDE.
2. Internally is more 'intelligent' than a USB stick, possibly with more advanced Caching algorithms and larger ram buffers.
3. It has WAY more storage.
4. for non mechanical faults(damaged parts),it is WAY harder to fix than USB Stick devices.
5. it is generally in a form factor designed to replace a hard disk.
Universal Declaration of Human Rights: Article 19
PostPosted: July 14th, 2010, 20:02
I'm not a "guru", but you may find the following article interesting.
The SSD Relapse: Understanding and Choosing the Best SSD:
http://www.anandtech.com/show/2829
I always find Wikipedia to be a good starting point:
http://en.wikipedia.org/wiki/Solid-state_drive
Users browsing this forum: No registered users and 77 guests
