 Post subject: WD2500BB-55GUC0 - I don't understand what cause the problem
PostPosted: June 25th, 2010, 7:12
Hard drive as in topic.
Format in PC-3K runs forever and never ends, If I verify disk, it runs very good until it reaches about only 13M LBA. From this point almost every sector is (INF) "bad" and last to the end of the disk.
Heads are ok, all modules checking ok, self-test runs smoothly and also is ok...
What the hell can cause this problem?
It would be a pity to trash 250GB...
Damon
 Post subject: Re: WD2500BB-55GUC0 - I don't understand what cause the problem
PostPosted: June 25th, 2010, 8:21
Clean both P- and G- , cycle power, regenerate translator, cycle power, run SS again.
OR there is a bad area exactly at 13M LBA that need to be isolated (cut zone) . Then it should be OK.
PostPosted: June 25th, 2010, 9:00
Thanks BlackST ;)
I will try and put the results, but what is SS for You?
PostPosted: July 14th, 2010, 6:17
I did SS again with your hints BlackST but unsucessfully. Thanks for help, cutting zone seems no sense for me, so hdd has been trashed :(
PostPosted: July 14th, 2010, 7:07
Why cutting zones has no sense ? it's better a "little less than 250 GB" than "0 GB trashed" drive :S
Take into account that sometimes downsized or refurbished drives are invaluable as intermediate carriers for shipping or for reviving "that" machine just-in-time. Also, it is environmentally friendly to recycle these drives !
PostPosted: July 14th, 2010, 7:32
Of course trashed means it will be recycling, be sure. I'm also environmental friendly as You BlackST :) Everyone should participate in recycling - I think that people slowly are getting used to that.
Thanks!
PostPosted: July 14th, 2010, 8:40
If heads were OK, it sounds like a translator issue. Maybe you binned this drive needlessly?
http://www.datasaversllc.com
PostPosted: July 14th, 2010, 11:05
he said that he followed my advice - clean defects and regen translator and SS so the translator is to be excluded.
PostPosted: July 16th, 2010, 0:49
Do a head test maybe one of the heads is bad .
Users browsing this forum: Jonny_Quick and 242 guests
