 Post subject: Maxtor Black Armour
PostPosted: July 23rd, 2010, 5:27
Any idea how you get round one of these if the disk is bad? it requires the password to be entered prior to anything. DDI does see it but everything is errors as its mega encrypted.
Password cannot be removed as far as I am aware, I have the correct password but the disk is that bad that when you enter the password in windows it only sees the disk as an encrypted volume
any ideas
thanks
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: Maxtor Black Armour
PostPosted: July 23rd, 2010, 5:28
i guess, the drive would need to work close to perfect for the password thing to then unlock the drive, as it cant do that the volume will stay jammed
PostPosted: July 23rd, 2010, 7:21
Make an 1/1 image and work off that one.
Bosse
http://www.rescue-it.se
PostPosted: July 23rd, 2010, 9:20
this is speculation since i have not had the luxury of dealing with any of the black armor drives yet.
But if DDI is only reading errors , as in it is not reading anything at all, the drive may be locked, which is different then encryption.
With data encryption you would still be able to image it, just not read the actual data.
If you have a pc-3000 machine check the drive to see if it locked.
If the device works like the smartware WD drives, you may need to run all your utilities through the USB enclosure device.
good luck
Users browsing this forum: Google [Bot] and 92 guests
