 Post subject: HDT722516DLAT80
PostPosted: July 29th, 2010, 13:30
Hey guys,
I have a clicking HDT722516DLAT80 that's been giving me problems. The drive will not go ready after a hotswap, and I know the heads are good as well (swapped patient to donor and heads work fine in donor). I was wondering if anyone has ever seen a case where the ribbon connecting the PCB and motor on the underside of the drive has gone bad. I personally haven't heard of this, but I don't know why it wouldn't be possible. I was just wanting some input from you guys to see if you've ever seen or heard of such.
 Post subject: Re: HDT722516DLAT80
PostPosted: July 29th, 2010, 13:50
AS patient heads work in donor, flex seems unlike. I would check for SA problems / modules OR problems at PCB level (NVRAM etc.).
This is what I understood from the post.
Last thing to consider is incompatibility between headstacks.
PostPosted: July 29th, 2010, 17:46
Have you ruled out bad PCB?
You tried starting the drive from resources and checking the FW?
Hotswap is not a good idea on Hitachi btw, due to the SA start addresses being different.
Users browsing this forum: Google [Bot] and 45 guests
