 Post subject: Heads replaced in WD5000AAVS but...
PostPosted: July 30th, 2010, 5:55
Hello everyone,
I had a WD5000AAVS which was dropped while working and at least 1 head was physically damaged.
Disk was not detected from BIOS.
I found a WD5000AAVS donor drive with matching 5th and 6th DCM characters and did the head replacement with confidence and no accidents but now the heads once powered up and disks start spining, they unload from the parking bay, slide almost to the center of the disk and slide back out to the parking bay without stopping somewhere to read. This happens 3 times and then disks stop to spin. Disk is again non-detectable in BIOS.
Any ideas?
 Post subject: Re: Heads replaced in WD5000AAVS but...
PostPosted: July 30th, 2010, 6:35
Well it goes to the centre because the SA is there. Its common on 3.5" - but it cant read it so it resets and tries again. Maybe you have SA damage.
Free Solutions
Yes, media damage or the other helluva of problems related to these "puppies" (WD). Check if heads still work on DONOR. If not...
PostPosted: July 30th, 2010, 6:51
Donor's heads work fine back on donor (donor is not a faulty drive).
Anything else non-dead end I could check apart from the SA?
PostPosted: July 30th, 2010, 7:47
Nothing.
PostPosted: July 30th, 2010, 8:05
how do you know how heads are acting? I take it you have viewing it with lid removed? I hope you put the HSA screw back in while doing this..... :roll:
PostPosted: July 30th, 2010, 12:59
gulliver wrote:
Any ideas?
Yes. Try various adjustments to the torque of the cover screw that connects to the headstack. Coupled with the fact that donor heads often have slightly different alignment than the originals, this can be a time consuming adjustment process.
PostPosted: July 30th, 2010, 13:22
Be careful when adjusting the torque of the head screw, not enough and you could severely damage the heads and platters.
PostPosted: July 30th, 2010, 13:45
Not quite as much as not having it in. :D
PostPosted: July 30th, 2010, 13:56
Lol, could be worth a try! :lol:
PostPosted: July 30th, 2010, 16:42
thanks guys :)
will try that and also see what MHDD is saying
PostPosted: July 31st, 2010, 17:32
Disagree.
This is not "common" on 3.5" drives.
only *some* model have SA in the middle, but not WD. :D
Janos
PostPosted: July 31st, 2010, 17:36
This drive needs special equipment to do the HSA/MHA replace.
Not all the recovery companies can do that.
If you are interested, i can help, before you will ruin the surface with useless attempts....
Janos
PostPosted: August 1st, 2010, 8:50
Sounds to me like heads are not a close enough match. In my experience, cover position in this family really isn't critical. If you know what to look for, you can match heads on the first try in most cases.
http://www.datasaversllc.com
PostPosted: August 1st, 2010, 10:09
it should be enough for match. :)
data recovery service[/b]
PostPosted: August 1st, 2010, 10:46
If you have UDMA, disable all but H2 (physical H0) and see what happens.
Users browsing this forum: No registered users and 93 guests
