 Post subject: pliz help momentus 5400.6 not working
PostPosted: August 6th, 2010, 6:07
had my hard drive which i accidentally dropped down.i tried to repair it .it was producing tit tit sound.after repair,it is seen using the device manager as an external drive but when you check properties it reads zero mbs.it is an external hard drive.it can not be seen when you use my computer icon.am using Windows xp.pliz assist me i want it working.by now it is fine but reads zero mbs
 Post subject: Re: pliz help momentus 5400.6 not working
PostPosted: August 6th, 2010, 8:53
As you now have 2 identical threads in different forums...... momentus-5400-detected-azero-t16592.html
i opened the hard drive to adjust spindells.where do i get mhdd or victoria
That dosn't look good!
So if you want help you better start off by describing EXACTLY what you did. Stage by stage!
In answer to your last question.
I would suggest to do the obvious!
PostPosted: August 6th, 2010, 9:19
U can get victoria and MHDD on hirens boot disk. Just google it. But i dont think it will help u much m8. Sry.
PostPosted: August 6th, 2010, 10:46
Yea id like to learn how to adjust the spindle too.
Free Solutions
PostPosted: August 8th, 2010, 7:08
previously my hard drive was producing tik tak sounds .so i opened the drive and took out the spindles ,adjusted the spindles then closed the harddrive.the hard drive stopped to produce the tik tak sound.but now it can detected but it can not be seen under my computer.it is detected in the device manager.it is seen with zero mb .please assist me
PostPosted: August 8th, 2010, 7:45
If you moved even few mm. the platters, cylinder / 'index'/skew alignment is lost. At this point probably with 5'000 dollars you have chances, otherwise data is gone forever.
PostPosted: August 8th, 2010, 8:07
Another classic!
Bitlevel Data Recovery
PostPosted: August 8th, 2010, 9:35
yikes.
Free Solutions
PostPosted: August 9th, 2010, 1:55
Adjusted the spindles?
This was a bad move.
Users browsing this forum: shubhsinghal and 71 guests
