 Post subject: win 98 startup screen
PostPosted: August 6th, 2010, 9:57
i'm using UBCD and i want to run MHDD. i get a win 98 (i have vista) startup screen where i can choose between start computer with ADAPTEC SCSI adapter support or without the support. what should i choose?
 Post subject: Re: win 98 startup screen
PostPosted: August 6th, 2010, 10:19
If you need to scan a SCSCI drive and have a adaptec compatible SCSCI PCI card isntalled in your system then choose Start with Adaptec SCSCI- otherwise choose without.
Either way- nothing will blow up.
PS Backup your data
Free Solutions
PostPosted: August 6th, 2010, 15:03
i tried both but then i get an error:
"the drive does not support LBA mode or not detected"
PostPosted: August 6th, 2010, 18:10
Well then- we need more information about the history and the specs of the drive.
I suggest not plugging it in any more - but are you sure the ide cable is ok and plugged in properly or sata?
does the drive knock / click - does it show in bios?
Free Solutions
PostPosted: August 6th, 2010, 18:28
the drive is WD 5000AAKS 500GB 7200 16MB. i'm pretty sure it's plugging ok, but i'll check it again. the drive doesn't knock / click, it doesn't make any sound (but it's alive, for now).
PostPosted: August 7th, 2010, 5:50
If you need data, I would suggest to stop playing with it and seek for a professional advice. You can try contacting Peter (pepe) on this forum. He is in your reach.
Bitlevel Data Recovery
PostPosted: August 7th, 2010, 10:14
ditto
Free Solutions
Users browsing this forum: No registered users and 49 guests
