 Post subject: Atola full ver. handling of disk Firmware issues. Requests.
PostPosted: August 6th, 2010, 11:24
Please see this thread:
wd1600aajs-00l7a0-03e01-needed-many-bad-modules-t16597.html
It is not a standard case of one or two bad modules, that I have handled before with auto repair. In this case Atola recommended further diagnosis.
Here are some points that it would be great to see Dmitry's opinion on:
1. I see the modules are copied, but are these copy 0 or 1? I only see one copy. It would be ideal to have two.
2. Is it possible to read the SA ignoring errors?
3. Can the entire tracks be saved?
Now some points and requests
As you may imagine ACE (and I guess SD) save modules are compatible with Atola modules. The format is just different. (modxxxx.mod in ace versus xxxx.m or xxxx.m~ for non readable modules in Atola). Why not incorporate a "compare and import" function whilst writing mods back via atola ;) After all, the biggest repositories and private stocks of good FW is in the ACE format.
Please other users chip in here with more Atola FW needs, I know that they are going to push this part of the product forward soon so there is a good chance our wishes will be heard.
For discussion purposes I have attached a full dump from a FW defective Drive done by Atola. Compare that to the dumps of your ACE and SD products.
Cheers..
WDC WD1600AAJS-00L7A0_01.03E01_WD-WCAV31761167.rar [2.31 MiB]
Downloaded 1242 times
 Post subject: Re: Atola full ver. handling of disk Firmware issues. Requests.
PostPosted: August 8th, 2010, 9:24
So far of the few drives I have recovered firmware issues were present in two- both were Seagate- and are unsupported. Seagate and WD are the brands I recieve most often.
PostPosted: August 8th, 2010, 21:47
mediaman
Answering your questions:
1) If I remember correctly, to read modules on WD drives we use a command that handles copies 0/1 automatically.
2), 3) This is not possible at this time
Regarding support for third-party modules: at this time the only option is to manually rename modules, which shouldn't be a big deal anyway. If anyone out there has to do that manual renaming a lot - please let me know, and we will add support for modules saved with PC3000/SD (I would need a full dump created by those tools).
Lately we've been focusing on imaging part a lot more than on any other feature - this is simply because this part of Atola Insight is used most. As I mentioned previously, we have to assign proper priorities to all those neat features, and therefore we judge mainly based on whether adding a certain feature significantly increases our customers' success rate. That's how it currently works.
Dmitry
PostPosted: August 16th, 2010, 22:07
Hello Dmitry,
I really can not see FW versions 0 and 1. in addition to the WD FW in the OP here is another WD. Please tell me where the two versions are to be seen.
Thanks!
132_WDC WD1600BEVT-22ZCT0_11.01A11_WD-WX80AA981574.rar [3.37 MiB]
Downloaded 1148 times
PostPosted: August 17th, 2010, 4:45
mediaman
Please see my previous reply. At this time there is no possibility to access copies separately.
Dmitry
PostPosted: August 17th, 2010, 10:12
Hello Dmitry,
Thanks but your reply was:
"1) If I remember correctly, to read modules on WD drives we use a command that handles copies 0/1 automatically"
I figured this must mean they are both read, but I guess its not the case.
I hope the FW side of the product can be beefed up soon!
Users browsing this forum: No registered users and 30 guests
