 Post subject: 80GB Maxtor DiamondMax Plus 9 Needs Rescue
PostPosted: August 10th, 2010, 3:48
Hello everybody,
This drive just started to fail and I need advice on where to take it.
It was running in a Dell / Linux box that hosted a pharmacy accounting server
that nobody backed up for over 3 years. File system was ext3, I believe.
I attempted to run SpinRite on the drive but SpinRite gave a warning that
SMART data showed the drive to fragile to attempt data recovery. Host Bios
recognized the drive but, at boot, warned about SMART data being outside
operating limits, but no further detail.
I need to get the data off this drive.
Has anybody got a reccomendation on a service they have had success with?
Thanks for reading this post.
-RH
 Post subject: Re: 80GB Maxtor DiamondMax Plus 9 Needs Rescue
PostPosted: August 10th, 2010, 3:54
Spin Rite is wrong choice !
Don't plug the drive any further if your data is really important, wait unless a Guru recommend someone for you..
RAID/Server Recovery
PostPosted: August 10th, 2010, 4:41
Dont use spinrite with that hdd. ditto above- dont plug in anywhere any more.
a guru will provide you with professional near you.
Free Solutions
PostPosted: August 10th, 2010, 9:43
i365, ontrack, drivesavers
from this forum jono-ats, harddrivespecialist, I'm sure there's plenty more. In general if anyone PMs you about it, read their posts and see if they sound like they know what they are talking about.
PostPosted: August 10th, 2010, 12:05
OK, Thanks very much for your responses and reccomendations.
The drive has been removed and I won't touch it again.
I never actually ran SpinRite; backed out if it after the SMART warning message
reccomended I not use it... so I guess it knows what it is talking about?
Will locate a professional.
Best Regards,
-RH
PostPosted: August 11th, 2010, 1:46
A pro can surely help to extract data. Then later the drive can be refurbished for re-use with factory procedures and will be 100percent OK for the remaining lifetime, if you want. Ask the nearest pro - I do it but I'm in Italy...
Users browsing this forum: No registered users and 249 guests
