 Post subject: FUJITSU MHV2120BH CA06672-B55600AP with bad head?
PostPosted: November 30th, 2009, 13:27
Hey my 120 gig was in a mac. Stopped working. put in external and hooked up to PC using MacDrive (Mediafour) to read it.
Does not show up at all
Does not show up under computer->management->Discdrives (Even as not formatted)
Does not show up in bios
I know the following.
The platter is not scratched.
I tried freezing it. - nothing
The head is not stuck
It spins up at power, then the head clicks twice, and it slows.
It repeats this process 6-8 times then stops.
Is this a head problem? I am not going to use a professional recovery service.
Would replacing the head help? or could it be somthing else?
Do I have to use the exact model number and Part number?
I have FUJITSU MHV2120BH CA06672-B55600AP
But I have found
Fujitsu 120GB SATA CA06672-B25600C1 MHV2120BH PL
Fujitsu 120GB SATA CA06672-B29600SN MHV2120BH PL
Fujitsu 120GB SATA CA06672-B35600TW MHV2120BH PL
Fujitsu 120GB SATA CA06672-B276000T MHV2120BH PL
 Post subject: Re: FUJITSU MHV2120BH CA06672-B55600AP with bad head?
PostPosted: November 30th, 2009, 14:48
fujitsu-with-bad-head-should-not-still-show-bios-t14100.html
ZeBong
" Россия еще раз"
PostPosted: November 30th, 2009, 14:57
ok, then I am on the right track.
Do I have to have an exact match for the donor?
Could one of those listed earlier still work?
PostPosted: November 30th, 2009, 15:00
you can try the model that you have.
ZeBong
" Россия еще раз"
PostPosted: November 30th, 2009, 15:04
This is the broken on that I have and need a donor for:
These are those that are as close as I can find:
Is there any expectation they they could work? Or do I need to keep watching until I find an exact match in the future?
Also for the heads, will firmware version matter?
PostPosted: August 11th, 2010, 16:34
Hi everybody.
I do have exactly the same situation, so its very important for me to know if they are compatible.
Please write if anybody knows anything about it.
Users browsing this forum: No registered users and 63 guests
