 Post subject: 2.5 to 3.5 adpaters back to front - Safety tip (add a fuse)
PostPosted: August 17th, 2010, 20:36
After recently becoming another statistic by making a mess of a 2.5 drive (inserting a 3.5 adapter wrong way round) I suggest that anyone using one should put a fuse on the adapter on the outgoing 5v line. This way if the incorrect pin is grounded this fuse will hopefully blow first. :idea:
Simply locate the 5V track coming from the power adapter, cut the track, and place a fuse across the gap (I have gone with a 1A fuse, which may not be enough) time will tell. The drive itself has a 2A fuse, so I wanted to go below this. Maybe feedback from the rest of the group will determine the best value to use here.
