 Post subject: SD tools & PC3k help
PostPosted: August 21st, 2010, 14:25
Dear Experts
How do i use the SD resources in PC-3000 like the ROM/Modules/Tracks
i know that in Pc-3000:
Modules Extension is: RPM
Tracks : .map & .trk
loader is: .LDR
and in SD:
Modules Extension is: .mod
Tracks : .tks
loader is: ???
so could someone please answer this question for me
because am stuck somewhere here with my resources
my Questions:
I tried to rename from SD to Pc-3000 but where is the Loader in SD? to use it in PC-3000
and so on
thnx in advance guys
 Post subject: Re: SD tools & PC3k help
PostPosted: August 22nd, 2010, 13:21
You manually need to edit the modules (split, joint and other such actions) in raw hex mode, in order to make them cross compatible.
Bitlevel Data Recovery
PostPosted: August 22nd, 2010, 14:19
well, could you please be more specific here, i mean split,join in hex
may i have an example ... thnx
PostPosted: August 24th, 2010, 3:56
i think the problem is that you can't simply rename:
the loader in maxtor is quite different in pc3k you have a .ldr file and in SD is boot.cod file but loader operation is a little bit different (sd loader involve more modules). NVRAM file of hitachi on the other side is the same and you can use on both (a simple dump :wink: ), in hitachi you have the .res file(for SD) which is not properly a loader but have some informations on SA structure (like module map) ... So may be as someone else suggested use a hex editor to check modules structure.
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: August 24th, 2010, 4:31
Just for the reference, here is the the conversion table for Seagate U6:
Salvation Modules Name PC3000 Modules Name
(In STU6_1.mod format) (In .RPM Format)
1 ----- RWF
2 ----- AT_STUFF
3 ----- SMART
4 ----- CSPT
5 ----- OVLY_CCT
6 ----- OVLY_ACT
7 ----- OVLY_CN1
8 ----- UDEFBAK
9 ----- USERDEF
10 ----- RESVDEF
11 ----- OVLY_AN1
12 ----- SYSVAR1
17 ----- OVLYA
22 ----- SECURITY
23 ----- OVLY_AT1
24 ----- VENDORSP
However, it's doesn't mean that won't need my previous advice!
PostPosted: August 24th, 2010, 6:16
thank you thank you really all of you here for the reply,
but may i ask this specific question about this matter
in case of WD HDD only, i will take this example as a reference for me and i will compare it with the rest
can i have this example please in both SD & pc3k?
lets say the Marvell
thank you again guys for the time and reply
PostPosted: August 25th, 2010, 8:16
i do believe that there are a lot of secrets here and No One wants to share some tips
soon or later it will come.
thnx for ur advices n tips
