Forum rules
 Post subject: IBM Think Pad / Lenovo FW
PostPosted: September 8th, 2010, 16:36
Does anyone know what FW is on the following drive? This drive came out of a IBM Think Pad...
Hitachi 7K500-160
HTS725016A9A364 7200RPM 160G
Lenovo P/N: 49N7019
Hitachi P/N: 0A73291
I'm trying to update the FW on following to replace it:
Seagate
ST9160412AS 7200RPM 160G
P/N : 9HV14C-300
Thanks,
 Post subject: Re: IBM Think Pad / Lenovo FW
PostPosted: September 8th, 2010, 16:40
:shock:
PostPosted: September 8th, 2010, 16:46
Keep on trying! :twisted:
DataRecovery.bg
PostPosted: September 8th, 2010, 17:14
Uhhhh... what?
PostPosted: September 9th, 2010, 2:30
Friendly hint:
If you put a hard drive in a fish tank do you think it will boot (might be hard to tell if you have an aquarium screensaver)? Or by putting a DVD in a VHS player you will benefit from a higher quality picture?
You might want to just put the hard drive in and see what happens, then if you have problems the people on this forum might be able to help.
PostPosted: September 9th, 2010, 3:25
Do You mean you have got one of those ibm laptops which produces an error code on the screen when you replace the hard drive for a different make/model?
Otherwise i'm not sure what you require.
PostPosted: September 9th, 2010, 5:47
Sorry, why is it necessary ??
Is the drive defect?
Is the laptop defect?
If you need advice, some background information would be helpful
PostPosted: September 9th, 2010, 12:42
NVM Guys.....false alarm!!! The following HDD works without a hitch in both the ThinkPad T60 and ThnkPad R400.
Seagate
P/N : 9HV14C-300
Sorry for any inconvenience... :oops:
PostPosted: September 9th, 2010, 14:48
Phew... We thought that you were trying to put the Hitachi 7K500 firmware on the Seagate :D
PostPosted: September 21st, 2010, 21:53
Not sure if this is what you are looking for... this is the info I have. Hope is fine for you.
HDD= SN 5VG4K681 ST9160412AS PN 9HV14C-300 FW=0002SDM11
:D
PostPosted: September 22nd, 2010, 0:18
Here is a 4SDM1 or 5SDM1 firmware update for the ST9160412AS:
http://support.dell.com/support/downloa ... eid=366463
It addresses an issue with excessive load/unload cycle counts. Owners complain of too frequent clicking associated with an aggressive internal power management (APM) setting.
Users browsing this forum: Google [Bot] and 87 guests
