 Post subject: SD tools & PC3k help
PostPosted: August 21st, 2010, 14:25
Dear Experts
How do i use the SD resources in PC-3000 like the ROM/Modules/Tracks
i know that in Pc-3000:
Modules Extension is: RPM
Tracks : .map & .trk
loader is: .LDR
and in SD:
Modules Extension is: .mod
Tracks : .tks
loader is: ???
so could someone please answer this question for me
because am stuck somewhere here with my resources
my Questions:
I tried to rename from SD to Pc-3000 but where is the Loader in SD? to use it in PC-3000
and so on
thnx in advance guys
 Post subject: Re: SD tools & PC3k help
PostPosted: September 6th, 2010, 2:12
Which type of drive? Not all drives support loaders, those that do do not do so in the same ways.
PostPosted: September 6th, 2010, 2:22
Are you talking about Seagate?
PostPosted: September 9th, 2010, 12:19
thatdellguy
am talking in general WD is the most am getting but having the segate as a sample might clear few points which i can compare with WD & others
and thnx 4 ur time here
PostPosted: September 9th, 2010, 13:34
WD is easy to do. In SD the extension on WD is .mod. Manually change this to .rmp. Then when you need a modules point to it and import it in the pc3k.
Iorana Haraharaini
PostPosted: September 9th, 2010, 13:40
u mean to .RPM
what about the modules numbering issue relative between both SD & pc3k
for example module 11 in pc3k = module 52 whatever in SD
this is my question...
and thnx for the reply :
PostPosted: September 9th, 2010, 14:27
Do this one. You can get a listing of the modules in the UDMA. I know it is possible. Print it out and then in the SD tools in download area where you back up the FW for the HDD you see a listing of the modules in there. Compare them. They are the same. They do not use MOD 11 in ACE and change it to MOD 52 in SD. This one is not possible at all. Compre the two listing. I find only that SD has some other MODs in this one that ACE does not have and there is a few extra in ACE that SD does not list. But the ones that are key mods in this that are needed for your drive are the same. It is possible to do this one in WD drives. I know in Maxtor the Mods are different and this one is another story on this one. But for your purpose in WD they can be used to upload and repair defectives Mods to your drive.
Iorana Haraharaini
PostPosted: September 9th, 2010, 14:42
thnx poehere
i got it, and many thnx again
PostPosted: September 11th, 2010, 6:30
For the researching stuff, rip off the modules with both tools from a known healthy drive, re-construct them, analyze them (checksum included), in the raw mode.
Sometimes, you may need to split and join the modules, as some modules ripped by both tools contains different number of sectors of SA. As Ann said above, both tools contains sometimes different information for the modules and this can only be examined manually. That's what I personally do if I need to.
If I remember, you had already created the exact topic in an another section of this forum too, where I supplied you a ready-made list of module conversion table as the reference. It falls under "thread duplicating" - not a great forum courtesy I must say.
Bitlevel Data Recovery
PostPosted: September 11th, 2010, 14:41
thnx man for the reply
:wink:
i got it
