 Post subject: WD Pinclite firmware needed for WD3200AAJS-22L7A0
PostPosted: September 14th, 2010, 10:56
Greetings all,
I have a need for the firmware from the following WD Pinclite drive: WD3200AAJS-22L7A0. Because there are some corrupt adaptives, the ideal firmware I am after is 000500E0. Any help is appreciated.
Steve
Disclaimer: I have posted about this one once before, but it has since fallen back a few pages so I am trying again.
 Post subject: Re: WD Pinclite firmware needed for WD3200AAJS-22L7A0
PostPosted: September 14th, 2010, 11:00
Checked but don't have it.
As an aside, I would not recommend overwriting modules on your bad drive with anything other than what you KNOW is exactly the same as what it has on there already. Especially not adaptives modules.
PostPosted: September 14th, 2010, 11:07
Sorry, closest I have is 500EQ.
Which adaptives are bad? Maybe the bad modules can be rebuilt from alternative donor depending on what they are.
PostPosted: September 14th, 2010, 11:31
those helps?
since ur not providing SN?
PostPosted: September 14th, 2010, 11:32
einstein9 wrote:
those helps?
You can determine FW version from SN ?
PostPosted: September 14th, 2010, 19:46
Thanks for the replies all. If it helps, the serial number is WMAV25440320. The drive build date is 12 APR 2009.
hddguy and drc- The situation is kind of ugly. Unable to read/write by ABA, so I couldn't manually edit or read anything. Both copies of modules 3, 41, 42, 43, 49 were corrupted. I thought I had the same firmware when I overwrote. It turns out I did not. The Deepspar folks seem pretty confident that identical firmware has a good shot of working, as they guided me to overwrite in the first place.
Einstein9- Those 3 are of interest to me, especially if the firmware is the same.
PostPosted: September 15th, 2010, 2:15
sorry most of them are: WCAV
none match
:oops:
PostPosted: September 15th, 2010, 9:17
I don't think everyone is quite on the same page here...
PostPosted: September 15th, 2010, 9:43
I got a little sidetracked when I see einstein asking for the SN, but spoke with him and realise it is simply how his FW collections are organised :)
@bytesback - all mods you list as bad consist of adaptive modules and Zone table. Im not so sure if replacing all of these will help much. Can you read SA tracks?
PostPosted: September 15th, 2010, 10:20
well, about how i org. my stuff, really and no joke, everybody and whoever visit my office, they always say that,
Am Well Organized .. i like to keep things in a way easy accessible for me only and as i heard for anyone else
PostPosted: September 15th, 2010, 11:06
You have UDMA, right? Do you not use the database?
PostPosted: September 15th, 2010, 11:32
1st. when i started using the udma i used to backup resources outside not inside DB
only from last month i started both just in case
working with DB is better/faster on finding/repairing
but, doesn`t matter, everybody pays his school fee`s,,,
and i paid my fees already
learned from my mistakes and thnx to Fabio really who told me about that
PostPosted: September 15th, 2010, 15:18
@hddguy,
I read and backed up what SA tracks I could, but of the 170 tracks I think more than 100 errored out and did not write.
I can only go by what deepspar told me, which is that the 4x modules can be overwritten by drives with the same firmware. I trust Yarek, he's a helpful guy.
Actually, since I have nothing to lose, would you mind posting the 500EQ firmware? It's a lot closer than I've found elsewhere. 100CS was what I had tried that didn't work.
PostPosted: September 15th, 2010, 16:23
Steve,
I forget, are you using PC3K (I would assume so, since you're talking to Deepspar)? Or something else?
PostPosted: September 15th, 2010, 18:05
drc,
You assume correctly. I am using PC3K.
PostPosted: September 16th, 2010, 4:31
You have already replaced these modules with mods from different FW revision?
I will upload the 500EQ as soon as I can get to the machine, maybe a hour or so.
PostPosted: September 16th, 2010, 12:57
hddguy,
I hate to say that I did, but... I did. Those modules have already been replaced from a different firmware. Nothing to lose at this point. I appreciate the help.
PostPosted: September 16th, 2010, 13:17
PM sent
PostPosted: September 16th, 2010, 13:29
BytesBack wrote:
hddguy,
have a look here @ the attach.
the log and tell me which one u wanted
WD3200AAJS-00L7A0.txt [3.99 KiB]
Downloaded 1075 times
PostPosted: September 16th, 2010, 16:41
Without the firmware version, I can only guess, so if you are willing, I'd like to try numbers 4, 10, 11 and 12, 13, 14. Beggars can't be choosers, so I'll take whatever you are willing to give me. I appreciate the help.
