 Post subject: Need FW for ST9500325AS
PostPosted: September 14th, 2010, 0:40
Did some one have FW for this HDD:
Momentus 5400.6
model: ST9500325AS
s/n: 5VE03SZY
P/N: 9HH134-566
FW: 0001BSM1
I can read FW under 7200.11/12 on HD Doctor. BIOS and Windows recognize the drive but unable to access. Victoria report IDNF on all sectors.
Thanks.
Sistrum Data Recovery
http://www.sistrum.mk/en
 Post subject: Re: Need FW for ST9500325AS
PostPosted: September 14th, 2010, 6:07
Can you read any of the surface,maybe in the first thousand LBA?
PostPosted: September 14th, 2010, 6:31
On DC I check sector 63 and I so info about NTFS, but on HD Doctor nothing. And i can read most of the FW modules.
PostPosted: September 14th, 2010, 7:22
I bet LBA up to a certain number are accessible, then nothing after, right?
Sometimes they are readable up to several million before blocked, but I had one which would only read up to sector 11 before nothing.
FW won't help you.
PostPosted: September 14th, 2010, 12:18
Thanks pcimage, any solution for this problem problem.
PostPosted: September 14th, 2010, 13:58
Yes there is a solution for this problem in most cases.
I know it and have solved many of these.
But it's difficult, time consuming and not for sharing, sorry.
PostPosted: September 14th, 2010, 22:34
No problem pcimage, I wil continue with work on this drive.
cron
